Looking to replace coil & icm
Old Jun 19, 2014 | 07:14 AM
Laymaster's Avatar
For a little while I've been having an issue starting the car in wet/damp weather and from the searches here it looks like a combination of the two is to blame.
The car has 147,000 miles on it and has the original coil & icm.
Is there any specific recommendations on which coil & icm to get or for the most part are they all the same for my 'lightly' modded car?
Thanks.
Old Jun 21, 2014 | 09:29 PM
SA68SS's Avatar
Re: Looking to replace coil & icm
GM ICM is the best. Coil does not matter so much. an Oreilly's re-man worked for me just recently, and it has a lifetime guarantee.
What symptoms other than hard to start?
How long since you changed your plugs?
Old Jun 21, 2014 | 09:51 PM
Laymaster's Avatar
Plugs --- not too long ago ... maybe 1,000 miles at most.
Car runs GREAT when the weather is fine. If it rained during the day I can't start it ... It cranks and cranks and goes putt-putt with a quick stall out. I also notice the RPM during crank registers quite low. From doing the search around here it seems a few others have encountered the same issue and have resolved it this way.
Where do you get the ICM from? Dealership only?
Old Jun 22, 2014 | 12:30 AM
Fatdog2's Avatar
Old timer here.Use a G.M. Coil.Been down the road with the after market crap.My02.
Old Jun 22, 2014 | 05:26 AM
timnfxr's Avatar
Rock Auto stocks AC Delco ICMs.
AC Delco ICMs/
Old Jun 22, 2014 | 08:17 AM
Kevin Blown 95 TA's Avatar
Don't overlook plug wires. They can cause that exact symptom when they get old.
Old Jun 24, 2014 | 07:33 PM
SA68SS's Avatar
The ICM can be tested at any good auto store. You need to take it off for the test. The coil cannot be tested.
I think you will find GM wants over 200 dollars for an ICM. I agree that the GM is the way to go. But coils, ...they are cheap. Plug wires are a good investment too.
Old Jun 24, 2014 | 07:36 PM
Laymaster's Avatar
I did not know the ICM could be tested ... So advanced auto or auto zone can test it?
Old Jun 24, 2014 | 08:22 PM
SA68SS's Avatar
I know Oreillys can, so I would think the other two could also.
grabbem88
Mar 18, 2015 01:25 PM
maybe2fast
Mar 16, 2015 09:45 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
USAirman93
Nov 24, 2014 03:37 PM
