Looking for LT1 ported chamber pics
Old Dec 29, 2005 | 10:42 AM
SiCk PuPpY's Avatar
I need to get 6-8 more CCs out of my combustion chamber and wanted to reference someones finished product; anybody have detailed pics they can post, link or send me?
Old Dec 30, 2005 | 01:40 AM
'94 Bad A Z28's Avatar
Re: Looking for LT1 ported chamber pics
Old Dec 30, 2005 | 01:41 AM
Never got pics of the final product, those were almost done, don't know if that helps you at all.
Old Dec 30, 2005 | 02:36 AM
Oh yeah, my heads are comming off the car and getting reworked so I will get pics of them then for you... Completely forgot about that. Should have pics in a week or so, I'll try to remember about this thread.
Old Dec 31, 2005 | 10:31 AM
A/G's Avatar
A/G
Did 'Carter' do a set of heads for you previously?
Old Dec 31, 2005 | 11:59 AM
SiCk PuPpY's Avatar
I'm specifically looking for work on the chamber itself. I need to open it up around 6CCs to drop my compression to 9.4 to 1 (it's at 10 to 1 now).
Old Dec 31, 2005 | 12:01 PM
Kevin Blown 95 TA's Avatar
I'm in the same boat as you. Building a 383 with 6" rods and it is about 9.5:1 SC with a -26cc piston, .005 deck & .040 gasket and the heads I've got. I have AFR LT4 heads at a minimum 56cc config which actually measure 58.5 cc or so, but need to be resurfaced. I called AFR up to see if they could enlarge the chambers and they said no because they would hit a water jacket - they can make the chambers smaller (ie: 74cc head down to 64cc) but not larger. All the heads there start out as 74cc and they mill them down to get the smaller chamber for the LTx. It looks like there's room to get a few more ccs out of the chamber, but I'm not sure how to attack it or even if I should. I still have the choice of gasket thickness & deck height, but don't want to end up with a big quench. Might have to live with what I've got, it's low boost anyway.
Old Dec 31, 2005 | 06:32 PM
SiCk PuPpY's Avatar
Lloyd Elliot informed me that a significant amount of material can come off between unshrouding the valves and rounding the spark plug knot on the factory LT1 castings. I would think you could get at least the same off the AFRs.
Another board member named kirschman posted up some excellent pics of his finished chambers; heres the link:
http://web.camaross.com/forums/showthread.php?t=418704
I'm having mine done right now by a local porter and will post up pics after they are finished.
Cheers,
John
Yes, that was them unfinished, now he (Carter) is doing a rebuild for me and reworking the heads, I willask him to get me some pics of them before he reinstalls them on to the car.
Old Dec 31, 2005 | 06:50 PM
Cheers,
John
Thanks - I took another look at the chambers and I think I will put a gasket on there and see where I can take some out. I'm sure I can do it, I just don't want to mess up the swirl. I'll take some before/after photos if I decide to go ahead and give it a try.
Old Dec 31, 2005 | 09:14 PM
SiCk PuPpY's Avatar
Be sure to leave a couple thousanths on the edges for gasket compression (squish/flatening).
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
LT14LIFE
Feb 9, 2015 09:35 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
