looking to install CSI elec. water pump
Old Jan 28, 2003 | 11:08 AM
foggerZ's Avatar
Talking looking to install CSI elec. water pump
Hey guy , im sure that a few of you have installed elec water pumps in your cars. My question is: what did you use to plug the hole in the waterpump, and what about the timing cover?
Old Jan 28, 2003 | 11:10 AM
GREGG 97Z's Avatar
This should answer all your questions:
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
Old Jan 28, 2003 | 11:19 AM
chesee48's Avatar
Re: looking to install CSI elec. water pump
where do u get yours BTW?
and what did u pay?
Old Jan 28, 2003 | 11:27 AM
97FormulaWS-6's Avatar
I got my CSI from a off-board GP that happened a while ago. I know Jegs carries then for $135 I believe.
The install was easy. The hardest part was removing the balancer to remove the drive gear off the timing chain, which is an optional step. I got my plug for the timing cover from a local parts store that had to special order a box of them in just for me. It's nice knowing the owner.
I've heard that a quarter and JB Weld works very well as well.
Old Jan 28, 2003 | 08:40 PM
foggerZ's Avatar
Hey thanks for the info i appreciate it alot.They were great instructions! Very detailed. About how long did it take you to get it done..Thanks for all your help.
Old Jan 28, 2003 | 08:51 PM
psychocabbage's Avatar
I had a Mezzerie Electric H2O pump.. I regretted it.. Not because of the power.. but cause it wasnt good for high speed prolonged runs...
I had a long 1 hour commute at high speeds (ususally seeing 150 but cruise control at 95) and that really hurt me since the Mez couldnt out flow the stock unit.. that made my engine have problems a couple times..
coolant would get too hot.. create hot spots and made my head gasket fail..
Old Jan 28, 2003 | 09:17 PM
chesee48's Avatar
so do u suggest the CSI one then?
there have been alot of good things bout the meizere but now im hearing some bad things. i'd rather save money then and get a CSI if those cause troubles ya know?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
