Looking for cam suggestions...
Old Sep 23, 2004 | 05:53 PM
BlackM6Z28's Avatar
I'm looking to replace the stock cam. Was gonna go with the LT4 hotcam, but willing to look at other options as well, especially anything from CompCams line-up. I wanna gain power of course and that nice lopey sound wouldn't hurt either Suggestions folks???
Old Sep 23, 2004 | 07:04 PM
Valkyn71's Avatar
Re: Looking for cam suggestions...
The 224/230 that im selling would be a good choice. =D
Old Sep 24, 2004 | 02:20 PM
TransAmGT94's Avatar
What kind of power do you want to make? Are you going to port your heads? By changing the cam you know you will need to at least do a valve spring swap. i would suggest a cc305 or a 306 depending on the work you will be doing in the process and the power you wana output. The other option is to call comp cams and talk to a cam tech the can custom grind one for your car so you dont over cam it. Its also a good idea to replace the lifters and the timing chain while doing a cam swap, and depending on your power output a new set of injectors will be needed to feed your beast. Post some numbers and some more info and maybe i can help you out more.
Old Sep 24, 2004 | 04:00 PM
Z06Z28's Avatar
I was looking at the hotcam as well and then changed my mind...
I spoke with Thunder and like everyone here suggests, they seem to like the cc305 of what I'm considering. I also heard the extreme 224/230 is a very good cam. Decisions is beating my head like indian drums. I'm wondering what the 305 can put out with stock heads on an A4? hmmm. I havent searched and found that yet. I would love to see 320-330 at the wheels but I'm still searching these threads.
Old Sep 24, 2004 | 04:30 PM
ONELOUDKAR's Avatar
I was running the cc305 on a 112lsa and the car sounded pretty dayum nice! I had mine dynoed with 124,000 miles on it and alot of things wrong with the car and it put down 292hp and 293 rwtq through an A4. I have now stepped up with a 227/233 on a 114lsa cam and a real low mile lt4 shortblock. I must say the car pulls hella hard with this cam. Soon as I get my TPS set right and hopefully the tranny will shift when told, I should be in the high 12's. No dyno numbers yet though but it wont be long before I do get some. Will post when I do. good luck with ur choice
Mike
Old Sep 24, 2004 | 04:35 PM
94 TA TT2S's Avatar
My car went 12.5 with Stock heads and Stall.....With Shinnies
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
