looking for a Cam
Old Dec 6, 2005 | 09:13 PM
Heatmaker's Avatar
Advanced Member
looking for a Cam
Does anyone know of a Cam that’s in between the GM846 & the CC306 without goign custom???
GM 846
dur 284/292
dur @ .050 222/230
lift w/1.6rockers .543/.563
lsa 112
& The
CC306
Part Number 07-306-8
Engine 1993-1996 Chevrolet
350ci,
LT1 & LT4,
8cyl.
Grind Number LT1 290HR-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.51 0.54
Duration At 0.006 Tappet Lift 290 307
Valve Timing At 0.006
Open Close
Intake 37 73
Exhaust 90 37
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 230 244
Lobe Lift 0.34 0.36
Lobe Separation 112
Old Dec 6, 2005 | 10:45 PM
blackztpi's Avatar
Re: looking for a Cam
There are really many, although it is hard to find one that works well on your setup. If you are going to be that picky on your cam selection (not a bad thing at all) just have a custom ground cam from bret bauer or joe overton. With a custom cam, you can taylor your drivability vs. hp and such. you can basically pick as lumpy or as soft as you want, more or less duration, and more or less lift. It all has to work, of course, but guys like bauer and overton can help you find that perfect cam without having to sacrifice much or anything in the major catagories. for 300-330 you can have a billet cam ground for you by those guys. they can also set you up with the best springs for that cam. Most shelf cams are around 250 already, so i'd rather spend the extra 50-80 bucks and get excactly what i want. I have a bauer cam and i love the cam, although a POS shortblock has held back some of the power. the cam i have has great low end and peaks power at around 6400rpm. the best part is, it doesn't need rpm to make power like the cc306 is often accused of. i believe the cam i have was tested at making around 300rwhp at around 4200-4500 or so and around 350 at 6400 on a completely stock motor (exception of headers). torque was equal to power throughout most of the powerband. peak torque (350ft.lbs. or so) was around 3500-4000 i believe. this is all done being more streetable than a cc306 in a 6 spd car. anyways, i'd spend the extra cash for a custom grind.
Old Dec 7, 2005 | 05:11 AM
RedLT4Mike's Avatar
CC-TN-227XR Comp Cams TN227XR Camshaft 227/233 duration @ .050", .560"/.569" lift with 1.6 rockers, 111lsa. Huge top end pull N/A cam, 3000+ stall converter recommended for auto cars. THE cam for street/strip cars looking for maximum power without sacrificing too much driveability. $255.70
Old Dec 7, 2005 | 11:32 AM
Heatmaker's Avatar
Advanced Member
That sounds pretty cool... hows it emissions wise... is it borderline?
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
