Lookin at doing these mods
Old Oct 20, 2004 | 06:43 PM
Mike44Mike's Avatar
Ok
I am going to get the lt4 hot cam and port the heads at a machine shop to match the cam. Im getting a full exhuast, Lt's, y-pipe, and borla cat back. Whould that get me in low 12's? If not than what additions should I get?
I might want to also port the Air intake manifold and throttle body with Cold air intake.
Old Oct 20, 2004 | 07:21 PM
lillbush5555's Avatar
Re: Lookin at doing these mods
My car with a CC306 cam stock heads and intake...Had Hooker LT with 3 inch y pipe no cats and hooker muffler, 4.10 gears I dynoed 353 RWHP and 342 RWT I also slapped down a 12.7 at 115MPH SO I am sure that setup will get you into the 12's
Matt
Old Oct 20, 2004 | 07:37 PM
96formulaLT1's Avatar
that should definately get you into the 12's, but with P&P heads i would strongly recommend a bigger cam. you have a stick or an automatic?
Old Oct 20, 2004 | 07:42 PM
Mike44Mike's Avatar
It is a 6speed. Why do you reccomend a better cam? I was told in another thread the the Lt4 hot cam gives good gains and sounds great and streetable at the same time with good fuel efficiency. What cam do you reccomend?
Old Oct 20, 2004 | 08:43 PM
ChrisUlrich's Avatar
Xe 227/233
Old Oct 20, 2004 | 08:46 PM
Mike44Mike's Avatar
What sounds better? Xe or Lt4?
Old Oct 20, 2004 | 08:49 PM
944v8inDFW's Avatar
A cc306 a real mans cam
Old Oct 20, 2004 | 10:22 PM
iNF3RNo's Avatar
The headwork would be wasted on a hotcam. The hotcam is mild, and flows just fine on stock heads.
If you're shelling out the bucks for the headjob, you really need to go with the bigger cam so it's not wasted. No smaller than cc305, with cc306 recommended, or the comparable XE cam.
Old Oct 20, 2004 | 10:26 PM
Mike44Mike's Avatar
How about Ported and polished Heads with the CC306 cam? Will that make a good street driver? I want a road car, not track car... but I also want it to sound crazy.
Old Oct 20, 2004 | 10:29 PM
944v8inDFW's Avatar
nice and streetable if the pcm is tuned right! It is streetable enough to drive it on a very technical road course It works well with ported heads for me anyway.
Did i mention a good PCM tune
Old Oct 20, 2004 | 10:31 PM
944v8inDFW's Avatar
oh yeah
it will not pass emmissions
Old Oct 20, 2004 | 11:31 PM
not trying to be rude or anything, but your goals for this motor are a bit to broadl. its going to be hard to have a streetable cam that lopes like a pro stocker, and makes good power low in the RPM range. like i posted in the other thread, and chris ulrich posted here, the XE 227/233 cam on stock heads would probably be your best bet. if you go to the group purchase forum, you will see that combination motorsports is offering a group purchase on their cam kits that include everything you need to install a new cam for a pretty low price. but hurry up because the deal ends this week i believe.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
karpetcm
Sep 15, 2015 11:07 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
CARiD
Jul 7, 2015 08:19 AM
