looken to do a header swap
Old Feb 11, 2009 | 12:33 PM
1slo93z's Avatar
I have a 93 z28 with a cold air and a 150 wet kit.Thinken longtube pace setters or a converter.If I do the headers Im going true duels out just before the rear tires.I have 1100 hund burnen a hole got kids so money isent that ezy these days.Just looken for a little more power. Any help would be cool thanks.
Old Feb 11, 2009 | 12:38 PM
pattracing212's Avatar
what are your plans for the car(drag, street), for just cruisin around town i'd say the pacesetters
Old Feb 11, 2009 | 12:52 PM
Red96Lt1's Avatar
Headders
Old Feb 11, 2009 | 01:31 PM
My Red 93Z-28's Avatar
150 is kind of pushing it with the stock pistons...if I remember right, 125 is about as high as you want to go.
I would go with Headers and exhaust, and then go with a converter later.
Old Feb 11, 2009 | 03:11 PM
1slo93z's Avatar
150 to much
Im going to back it down to 125.The car goes to the track and car shows. I might put 1200 miles on it a year.
Old Feb 11, 2009 | 04:46 PM
1200 miles is at least 2400 passes down the strip
Mileage doesn't matter because you aren't spraying the entire time you are driving, for your piston's sake...125 would be good.
Old Feb 11, 2009 | 06:05 PM
6SpdLT1Z's Avatar
I'd take the money and invest it in a English Composition night class at the Community College.
Old Feb 11, 2009 | 08:58 PM
it took me way too long to understand where you were going with that...lol
Old Feb 11, 2009 | 09:12 PM
6SpdLT1Z's Avatar
Maybe you should join him.
Anyways, OP, I'm not sure what your question is. Are you asking whats better, a stall or headers?
Anyways, freeing up the exhaust (long tubes and true duals) will gain you quite a bit of power and really wake up your car, I think headers are one of the best bolt ons you can get, especially if you are also looking for some more growl from the exhaust.
Stalls are great and will really help your car hook, however I think I'd go with full exhaust first. Also, when you decide to go with a stall, do your research and know that you get what you pay for. Buy a good name brand stall.
Old Feb 12, 2009 | 02:54 AM
PoorMan's Avatar
FYI: Be prepared for a header bolt to break off in the head. Happens alot.
Old Feb 12, 2009 | 06:15 AM
RamAir95TA's Avatar
This is not necessarily true...at least I wouldn't call it happening frequently.
I have done about a dozen header installs and not once have I had a bolt break off in the head. I have seen stripped threads, but never a broken bolt. This is because the factory used generous amounts of anti-seize compound on the OEM bolts. The only time I can imagine a bolt breaking off in the head is if an aftermarket bolt was put in without anti-seize. Just make sure you have the ratchet centered and don't put any lateral pressure on the bolt.
You should have little to no problem removing the OEM bolts. Half of the problem is just getting to them. Trust me. Others will agree.
Old Feb 12, 2009 | 01:06 PM
agreed, i have done four header swaps on lt1's and a couple ls1's, i've never had a problem with header bolts breaking off in the head
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
transam_388
Mar 15, 2015 11:53 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
