Look what I found in my Oil Pan!!
Old Aug 5, 2005 | 08:20 AM
gamecockfan04's Avatar
http://xs40.xs.to/pics/05315/MetalinOilPan2.jpg
After going to start the car 2 months ago and hearing/feeling a clunck near the bottom of the engine, replacing the Opti, replacing my lifters (3 were cracked), finding a hole in my Oil Pan (cracked from the inside out), finding a severly bent push rod on #6 cylinder(the one closest to the rear of the engine) and having a bad clack on that valve , I was all set to pull the head, when I decided to drain the oil and check it out with a magnet and thats what I found. I was thinking it was a spun bearing, but someone else said it looked like pieces of a piston (sorry for the pic quality).
Old Aug 5, 2005 | 08:41 AM
Re: Look what I found in my Oil Pan!!
Yeah, pretty bad quality...does look piston-ish, though.
Old Aug 5, 2005 | 08:58 AM
WS Sick's Avatar
iS it a ferrous metal? If its aluminum it's more than likely piston skirt.
If a magnet sticks to it it's no telling.
Old Aug 5, 2005 | 09:02 AM
Yea, a magnet want pick up Aluminum, so its got to be metal from somwhere.
Old Aug 5, 2005 | 03:46 PM
budstoy's Avatar
If the pieces are magnetic then most likely gear parts, from oil pump drive gear to cam or timing chain sprocket gear to water pump gear. Good luck, I predict a rebuild is in your future!
jer4251
Sep 21, 2020 09:42 PM
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
