Longtubes and transmission clearance
Old Feb 6, 2004 | 09:36 PM
03RSIX's Avatar
For all of you that have Hooker LT's: can the transmission be taken down to do a clutch w/o having to remove the headers? I sure do hope thats the case....thanks in advance.
Old Feb 7, 2004 | 02:56 PM
My95Z's Avatar
all depends on your setup and what y-pipe you have... if memory erves me right, you will need to try and move the headers out of the way(which probably means out or loose enough to move around. I may be wrong but that is what I htink
Old Feb 7, 2004 | 05:44 PM
$hawn's Avatar
Well, longtube headers go straight back, but on how the y pipe was done might need to drop that, and proabaly need to take out the O2 sensors sense they face inward.
Old Feb 7, 2004 | 06:09 PM
carlos64030's Avatar
Your headers won't have anything to do with removing the tranny. However, you will have to remove the y-pipe.
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
97SSdude
Aug 21, 2015 09:36 AM
jbc3
Jul 28, 2015 12:24 PM
mrwz28
Jul 8, 2015 09:11 PM
