longtubes hang low
Old Aug 3, 2007 | 03:31 AM
Daniel6718's Avatar
longtubes hang low
on drivers side, im assuming its normal i see it on a lot of camaros with longtubes
i replaced my mounts with poly, and trans mount...all my exhaust is mostly tucked higher then my subframes except right under the drivers seat...
yall think i could raise it with washers under the drivers mount, between the k-member and mount and block and mount? any better ideas? i really just dont wanna ding up my headers a lot, its not terrible but it does ride close to the ground and id just like both sides to be even
Old Aug 3, 2007 | 04:37 AM
'94 Bad A Z28's Avatar
Wouldn't worry about it, dunno why one side is lower than the other though...
Mine are pretty even, as are almost everyone else I would assume.
Old Aug 3, 2007 | 06:18 PM
SS1156's Avatar
94 A Bad Z28, What kind of exhaust are you running?
Old Aug 3, 2007 | 08:34 PM
FASTFATBOY's Avatar
Look under the car, the drivers side is lower because it has to clear a floor brace.
(Most likely)
David
Old Aug 3, 2007 | 08:56 PM
JP95ZM6's Avatar
Mine wound up with the driver's side lower, too, due to abovementioned floor brace.
Old Aug 3, 2007 | 09:24 PM
PaceSetter LT's and Y-Pipe, 3" I-Pipe back to a flowmaster 80 series with the inlet opened up to 3". I have a SLP Dual/Dual rear section sitting in my garage waiting to go on the car.
Old Aug 3, 2007 | 10:24 PM
Bersaglieri's Avatar
Wow, I wish mine was that clean underneath. Never noticed if one was lower...
-Dustin-
Old Aug 4, 2007 | 01:23 AM
Daniel6718's Avatar
i think its a hooker thing...my driver side has clearence for the floorboard....i seen some pacesetters and none of them do
Old Aug 4, 2007 | 09:32 AM
JP95ZM6's Avatar
-Dustin-
Thanks. That's the best looking side of my car, but unfortunately only the occasional slow pedestrian ever even gets to appreciate the view.
Mine are Pacesetters, too, BTW.
Old Aug 4, 2007 | 08:31 PM
I'm just glad I had that intake leak for so long, it kept mine from rusting. Unfortunately it couldnt save my collectors, they're bare steel nowadays.
-Dustin-
Old Aug 4, 2007 | 09:08 PM
lethal93ta's Avatar
I have jet hots and mine are the same on both sides, I have a hooker Y pipe that is notched for the brace thats there.
Old Aug 4, 2007 | 09:18 PM
buzz12586's Avatar
Hey I noticed you have some kind of sealer where the collector and y-pipe meet. Mine is leaking from there and I was wondering what you were using?
Old Aug 4, 2007 | 10:05 PM
Now that I think of it my Hookers with Mufflex ORY do hand lower on the drivers side. It's cause the Y isnt notched.
-Dustin-
Old Aug 5, 2007 | 01:45 AM
It's some type of "weld putty" but it doesn't work that great, I am going to put band clamps there when I get some extra money.
Old Aug 5, 2007 | 04:51 AM
SS RRR's Avatar
The raised portion of the cross brace which makes contact with the y-pipe can be ground down so you don't have to notch anything. It's real easy to do with a good grinder and takes seconds. That way you even have good clearance so the exhaust won't smack up against the chassis when torque is applied.
bunker
Jan 30, 2016 08:09 PM
97SSdude
Aug 21, 2015 09:36 AM
jbc3
Jul 28, 2015 12:24 PM
mrwz28
Jul 8, 2015 09:11 PM
