Longtube Header Gasket for Ported Heads?
Old Aug 25, 2009 | 11:36 PM
SteveNof1995's Avatar
Hello All,
I have a '95 Formula with Lloyd Elliott heads and Jet Hot Longtubes. I am looking for input as to what is the best header gasket that will work with this set up.
Forgive my ignorance but it seems that a lot of header gaskets I come across for LT1s do not accommodate larger and ported exhaust ports on the heads outside the ones that initially came with the headers. I would hate to use a gasket that would restrict the exhaust due to small exhaust port holes. Thanks
Old Aug 26, 2009 | 07:51 AM
bw_hunter's Avatar
I have jet -hot LT headers and used Mr. Gasket UltraSeal #5965 gaskets. They had a slightly smaller opening than they headers but had so much material I could match them pretty easily with an Exacto knife.
I'm not certain if you can find a gasket that exactly matches the headers..I've only used a few different ones over the years and they are were close but not exact.
Old Aug 26, 2009 | 05:14 PM
lt1-xjs's Avatar
I run the Felpro 1406 which has the large d-port design. They should work for you.
Old Aug 26, 2009 | 08:47 PM
Thanks for the input guys....Anybody else have any input on this; possibly anyone running Earl's and/or Percy's?
Old Aug 26, 2009 | 08:58 PM
Black396's Avatar
Stay away from earls or percys. I have had no luck with them and either has my buddies. Sometimes the simple cheap solution works like the 1406 fel pros. They work great and are very cheap.
Old Aug 27, 2009 | 12:59 AM
Bersaglieri's Avatar
I ran those for the last 6 years, took them off last week, still in great condition.
-Dustin-
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
k1996z28
Jan 21, 2015 07:22 AM
