Longtube Header Gasket for Ported Heads?
Hello All,
I have a '95 Formula with Lloyd Elliott heads and Jet Hot Longtubes. I am looking for input as to what is the best header gasket that will work with this set up.
Forgive my ignorance but it seems that a lot of header gaskets I come across for LT1s do not accommodate larger and ported exhaust ports on the heads outside the ones that initially came with the headers. I would hate to use a gasket that would restrict the exhaust due to small exhaust port holes. Thanks
I have jet -hot LT headers and used Mr. Gasket UltraSeal #5965 gaskets. They had a slightly smaller opening than they headers but had so much material I could match them pretty easily with an Exacto knife.
I'm not certain if you can find a gasket that exactly matches the headers..I've only used a few different ones over the years and they are were close but not exact.
oldschool
Feb 9, 2016 09:21 PM
