Long Tubes, KM, & False knock ??????
Old Jan 3, 2005 | 05:55 PM
FIREHAWK #7's Avatar
If my cars Hooker Long Tubes constantly keep hitting my cars K member, will my computer read this as false knock...... I also do have an lt4 knock module...... The Long Tubes used to vibrate and rattle only on take off, but after today that i installed the Borla catback the LT's now rattle/vibrate more while driving, not just on take off..... THX
Old Jan 3, 2005 | 08:00 PM
OBE1 95Z28's Avatar
Re: Long Tubes, KM, & False knock ??????
I think you'll definitely see false knock. See if a local F-Body buddy has a data capturing program like Diacom to read you knock sensor to verify. Headers can even produce false knock without mchanical interference.
Old Jan 3, 2005 | 08:41 PM
Makaveli's Avatar
if you hook up a program to it and see it is getting knock, how do you know its false? do you use higher octane gas and see if the reading stays the same?
Old Jan 3, 2005 | 08:51 PM
OBE1 95Z28's Avatar
With the gas tank on empty, fuel up with 100 octane. If you see a reduction in knock, it's real knock and you need to find the source of the knock (bad wires/plugs, dyno tuning required, etc). If the knock remains the same with the high octane gas, it's probably false knock.
Old Jan 3, 2005 | 11:39 PM
So does anyone around the HOuston area have some sort of program that will let me see how much timing my car is pulling out?????
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
drptop70ss
May 4, 2015 08:22 PM
4586
Mar 18, 2015 06:31 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
