Long tubes hitting K member..
Old May 20, 2004 | 07:45 PM
CoUnTryMuZiCZ28's Avatar
my jet hots are hitting my k member on the passenger side on the part that is just behind the motor mount.. its right near where the back bolt is to drop the k member.. I tried to pry it off, that didnt work so well, i was afraid to push so hard on my headers.. anyone have this problem or know how to solve it?? It makes a slight rattling when im letting of the clutch in 1st and on the 1st and 2nd shift about 20% of the time..
Nick
Old May 20, 2004 | 07:56 PM
viperkiller's Avatar
yep. you need to grind it down a little. it doesnt take much. i knocked mine down with a dremmel.
also check the a/c lines under the first primary on the same side.
Old May 20, 2004 | 07:58 PM
I dont think you understand where its hitting... To grind this down would mean taking the headers off.. I install headers for people, i know all about the AC line, lol..
Old May 20, 2004 | 08:05 PM
i think i know, mine where close there to. right where the tubes come down just before the turn to the back, right.
what you could try is unbolting the transmission mount and jacking the back of the tranny up, that should give you the clearance between the primary and k member. thats why i used the dremmel with the porter bit to reach between there.
Old May 20, 2004 | 08:29 PM
yea..
Old May 20, 2004 | 08:46 PM
Somnambulist's Avatar
what are YOU up to tonight big boi?
Old May 21, 2004 | 09:06 AM
LWillmann's Avatar
The solution for me was to replace my motor mount. I installed a poly mount on that side and it's not touched since.
Still have to do the driver's side though.
Old May 21, 2004 | 09:14 AM
JONEZ_Z's Avatar
Mine is doing the same thing. It was fine at first but i think with all the power my car is making now, it started to loosen up the motor mounts and now it rattles like hell at idle. Drives me nuts. I have to figure out what im gunna do. Where do you get those poly mounts?
Old May 21, 2004 | 11:45 AM
LWillmann's Avatar
I got mine from thunder racing.
Old May 21, 2004 | 12:28 PM
Cmr0z28's Avatar
Told you to get the pacesetters
jk, good luck
Old May 21, 2004 | 01:07 PM
bunker's Avatar
Ohh thats nice 1 poly mount, butchers LOL.
Old May 21, 2004 | 02:53 PM
i have poly mounts
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Mar 23, 2015 08:06 AM
4586
Mar 18, 2015 06:31 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
