Long Tubes + Custom Y-Pipe and now HALF as loud!?
Old Jun 25, 2004 | 10:55 AM
)2overt SS's Avatar
Unhappy Long Tubes + Custom Y-Pipe and now HALF as loud!?
EDIT: Here are some pictures... you'll have to read a bit for them to make sense though Sorry their not as big as I drew them in the first place
These are pics I drew of what I wanted my Y-pipe to be, and that the exhaust shop did:
What I Wanted
What They Did
What gives? I thought Long Tubes and a Y-Pipe were supposed to refine your exhaust tone and even make it slightly louder. Not make it twice a QUIET!
I finished up my long tube install.. and then drove it to the exhaust shop. They fabed up a y-pipe for me, but my 4 O2 bungs were open, and besides the raspeness of the open holes, it sounded great! I was just the right tone and loudness.
But today I put all the O2 sensors back in.. and it is ridulously quiet. I know it's not just me being used to open headers and what not because before my header install. Every time I started her up, I would leave my door open so I could here the 2OTL.. and I loved hearing it. And also when crusing in 3rd at 2 thousand RPMs it's just the right tone that I love.
But now.. when I start it up, it's barely audible! And at 2 thoudans RPMs crusing, NOTHING!
To be honest, I must say it is a very refined tone.. very LSx Corvette kind of tone.. But I don't want refined! I want my growl back! I don't want it to pur
I was NOT impressed with the custom Y-pipe... it's hard to explain here and I don't want this to be too long, but it was not very "thought out". The work was good.. but not the design.. I'll try and post pictures.. but my main question is...
Do Long Tubes make your exhaust more quiet? Or is this problem within my Y-pipe...? What should I do?
Thanks guys
Old Jun 25, 2004 | 11:14 AM
stonez96z28's Avatar
mine is alot louder through my flowaster....sounds good.
Old Jun 25, 2004 | 11:31 AM
Z06Z28's Avatar
Your LT's of how your describing the sound... makes me think that your already going deaf by the new sound decibel that now you can't hear them rumble...maybe your use to the LT sound already...I have Shorties, no cats with a cutout exhaust dump and I'm already use to that loud "Brahhhhh" sound.. "I like it alot" ...wait..what did you say, I can't hear you?
Old Jun 25, 2004 | 11:32 AM
Cmr0z28's Avatar
Mine definitely got louder. I had my Hooker cat-back with stock manifolds and cats, then went to Pacesetter LTs and no cats with a 3" mandrel bent Y-pipe. It could definitely be your Y-pipe depending on the size/bends.
Old Jun 25, 2004 | 11:44 AM
Z06Z28's Avatar
I would love to see some Digi pics....is it deformed and stuff? You should of did 3 inch pipes from front to back...and what LT's did you get? some LT's have custom y-pipes you can buy to make install hecka easy.
Old Jun 25, 2004 | 11:55 AM
)2overt SS's Avatar
I wanted to do 3 inch all the way back.. but I got a really good deal on two 2.5 inch cats.. so I figured.. I'm not going to be losing any flow because there are two of them, and they will converge into a single 3 inch. And also.. groud clearance is already tight with the 2.5 inch pipes..
I can take some digital pics now... however the car is not up in the air. But it will give you an idea.. They will be posted in about 15-20min.
btw.. they are Jet-Hot LTs...
Old Jun 25, 2004 | 12:20 PM
)2overt SS's Avatar
Here are the digital pics as requested.. I'm sorry that they don't show much because the car is on the ground. If you guys think pics of it in the air will really help.. I'll get them for you.
Passenger Side
Passenger Side 2
Front Looking Back
Back Looking Forward
Driver Side
Driver Side 2 - Shows bad intersecting of two pipes
Old Jun 25, 2004 | 12:38 PM
speed_demon24's Avatar
Its supposed to be a Y-pipe, not a T-pipe. Thats killing your flow, and mabey your sound. If I were you I would get a new y-pipe fabbed up and ditch the cats.
Old Jun 25, 2004 | 12:39 PM
ponyackn's Avatar
In that 2nd pic that you drew, is the driver's side pipe on the y pipe heading back towards the front of the car as it connects at the y? I would think that that would create horrible flow
Old Jun 25, 2004 | 12:45 PM
TedH's Avatar
If you provided the drawing to the shop, and they deviated from the drawing, it was their responsibility to call you, inform you of your options, and only proceed when authorized by you. Looks to me like they provided something different than what was requested. They should correct the situation at no additional charge. I would be upset.
Old Jun 25, 2004 | 12:49 PM
Berly_BoneStock's Avatar
buy a mufflex and ditch the cats!
Old Jun 25, 2004 | 12:57 PM
Z06Z28's Avatar
yea, I would suggest just ditch the cats as well....causing too much of a hassle... ha ha @T-pipe..
Old Jun 25, 2004 | 01:15 PM
Steve0's Avatar
That cracked me up. It's the truth though.
Old Jun 25, 2004 | 01:39 PM
tagz's Avatar
If it was me, i would have bought this
http://www.jegs.com/cgi-bin/ncommerc...14&prmenbr=361
and welded it up my self. but now everyone has a welder unfortunatly.
for 40 bucks, i would buy that, and put it on ur cat back, and tell the shop all you want them to do is get the headers to those two pipes and be done.
Old Jun 25, 2004 | 01:41 PM
)2overt SS's Avatar
Yes lol.. my drawings are NOT exaggerated. The driver side pipe is angle more toward going AGAIST the flow of the passenger pipe than it is heading back.
Ditch the cats? Sorry.. can't. I HAVE to pass emissions. Unless there is a good chance I will pass without them.. but I doubt it.
How much flow am I really losing through two 2.5 inches verses two 3 inches? I mean, wouldn't two 2.5 inches be enough? Thats what true duals would run through.
I am definately going to bring it back to the shop and have a talk. I want to hear my car again!
Any other suggestions guys? I need my cats though...
