Long Tubes for 96 LT1
Old Mar 12, 2008 | 10:21 AM
lbftbljck's Avatar
I am yanking my trans and sending it up to CPT to get a full race build put in. While the car is down for a little while. I'm thinkin about puttin a set of headers on it. I want to put a set of long tubes on, and also be able to run cats b/c of emissions, damn VA laws.
Thunder racing has a deal "LT1 Headers & Dual-Cat Y-pipe Package." These look like they are mid lengths. Anyone have a suggestion as to which ones would be the best? I know Kooks are prolly the best ones, but will A Speed & Marine do the job?
Old Mar 12, 2008 | 10:33 AM
BUBBA's Avatar
First of all, long- tubed headers with he preferred way to go if you can. Coated lts are the the only way to go. Pace setters, so I hear, are the least expesive and best fitting way to go. Kooks, Grotahans, AS&M are good quality, if not the best fitting, but....if you have strong enforcement of emissions, you are not supposed to move the postition of the Cats or change the number of cats that came with the car. So if you aren't plannning to move the position of the cats, going with anything that requires moving the position of the cats, e.g., long-tube headers, so-called middies, etc. are not going to work for you.
Now, if they never check your exhaust system, then by all means, opt for Stainless, Ceramic-coated long-tube 1 3/4, top of the line headers.
JMHO
Old Mar 12, 2008 | 10:38 AM
BUBBA's Avatar
And...another option would be to go with, e.g. AS&M 1 3/4 headers with electric cutouts, but of course they would be strictly for off-road use or out of earshot of the cops.
Old Mar 12, 2008 | 10:48 AM
2000GTP's Avatar
Kooks is the only one that offers a catted y-pipe for long tube headers that I know of. I have the Pacesetter long tubes with emissions fittings and I had my y-pipe modified with a pair of high flow mini-cats. The passenger side is not a big deal, there is plenty of space there, the drivers side however, is trickier due to fuel/brake lines, torque arm, ect in the way. That is where a smaller length cat comes into play.
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
Queens94z28
Nov 20, 2014 06:03 PM
Jul 4, 2005 05:00 PM
