Long Tubes and 168 teeth flexplate?
Old May 23, 2007 | 04:17 PM
JodyJ's Avatar
I'm finally going to install my long tubes that I've had over 1 1/2 years, but my problem is my engine builder put a 168 teeth flexplate in when I had it built a couple of years ago.
Does anybody know if the long tubes will work with a 168 teeth flexplate?
Thanks,
Jody J.
Old May 23, 2007 | 04:22 PM
2000GTP's Avatar
They will work fine. The flexplate in no way has any contact or correlation to the exhaust system, or the long tube headers in your case.
Old May 23, 2007 | 04:25 PM
JodyJ's Avatar
But what about the starter. I know with the 168 teeth flexplate, it pushes out the starter which I think might interfer with the long tubes.
Old Jun 27, 2007 | 08:21 AM
96ZRDR's Avatar
I am in the same situation, does anyone know which starter to purchase for a 168 Tooth flexplate? Factory Starter wont fit, after engine builder used a B&M 168-tooth flexplate. It pushes the starter down about 1 inch.
Anyone?
Old Jun 27, 2007 | 12:11 PM
1racerdude's Avatar
Part #3510 at AZ
Old Jun 27, 2007 | 07:38 PM
JodyJ's Avatar
Anyone?
I'm using a PowerMaster starter that fits both a 153 and 168 tooth flywheel.
http://jody.dltechnologies.com/powermaster/small-a.jpg
http://jody.dltechnologies.com/powermaster/small-b.jpg
http://store.summitracing.com/partde...5&autoview=sku
http://www.powermastermotorsports.co..._starters.html
Jody J.
Old Jun 28, 2007 | 08:33 AM
96ZRDR's Avatar
I bought the autozone starter yesterday, #3510, and did a pre-fit and it seems to line up correctly. It also cleared the headers. We will test today if I have a chance after work, but you do need 2 long studs.
Starter was $35 + $15 core.
Old Jun 28, 2007 | 10:45 AM
1racerdude's Avatar
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
drptop70ss
May 4, 2015 08:22 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
