Long Tubes with 1 inch drop will it work?
Old Feb 16, 2003 | 05:21 PM
NHSZ28's Avatar
I have a 1994 z28 and iam going to be lowering it 1 inch with hotchkis springs and iam going to be getting headers also and looking at long tubes from jet hot so would i have a ground clearance problem with that? I think it should work i see guys using eibach 1.5 lowering springs with long tubes. I just have to take it easy of speed bumbs but i all ready do that. what else can you guys suggest so i dont hurt the headers or y pipe? iam going with a stainless works y pipe that is what ls1 speed suggested is that a good one if so how big 3 in????
Old Feb 16, 2003 | 05:46 PM
chesee48's Avatar
ive heard people being ok with 1in drops...anything more will def be pushing it...Just make sure it doesnt sag more the 1in they claim, b/c you'll be in trouble
stik6shift93's Avatar
I have flp and have it lowered about 2 inches in the front, as long as you're careful you won't ground them out.
Old Feb 16, 2003 | 06:34 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
you will not have any issues
Old Feb 16, 2003 | 07:58 PM
Blue89Bird's Avatar
get a nice ypipe that tucks up good and you will be fine.
Old Feb 16, 2003 | 09:06 PM
96SilverRam's Avatar
You won't have a problem with longtubes if you do the FLP. I have almost 3 inches of drop and really have only hit the longtubes once and that was on a speedbump. I would still recommend always driving with caution, but don't sweat it. You will like the look of a lowered car and love the sound of your longtubes. Mike
Old Feb 16, 2003 | 10:05 PM
redlt1z28's Avatar
Clearance?
Hey i was wondering about the same thing. But i want to go with the Hooker Long Tubes with a mufflex y-pipe and i also want to drop it about 1" with the eibach pro kit. Will this work? Will i rub everywhere? I don't want to have to worry about scrapping the bottom on every little bump. Does anyone have this setup or has pics? Thanks
Old Feb 16, 2003 | 11:11 PM
1" drop with Hooker and any y-pipe will be close. Just be careful the Hookers sit alot lower than the FLP's.
Old Feb 17, 2003 | 12:34 AM
lt4 fd's Avatar
But as long as you avoid speed bumps and the road is flat for the most part you shouldnt have any problems with even a drop more than and inch with hookers correct?
Old Feb 17, 2003 | 01:58 AM
I think Hooker is a great header, but I would not give up the additional ground clearance that FLP provides !! IMO
Mike
LT14LIFE
Feb 9, 2015 09:35 PM
Jan 5, 2015 07:14 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Queens94z28
Nov 20, 2014 06:03 PM
Jul 4, 2005 05:00 PM
