Long tube w/ true dual VS shorties and Ypipe?
Old Sep 11, 2004 | 12:51 AM
revkevs94Z28's Avatar
I'm looking to change the exhaust on my 94 Z and was wanting some input.
I have considered just buying some shorties with a Ypipe and use my current system but would really like to go with long tubes and do a true dual setup w/ an x pipe and maybe some dynomax bullets. Should I use 2/12 or 3" pipe and what type of mufflers would work and sound good. How many of you have done this and how hard is it to do a true dual set up? I live near OKC OK and don't know many people around here with true duals on a Z.
Any input is appreciated!
______________________
1994 Z28 Cold air, 1LE elbow, tb airfoil, tb bypass, 160, lt4 knock sensor, maf descreened, shift kit, magnaflow hi flow cat, dynomax bullet
Old Sep 11, 2004 | 10:19 PM
Josh-'04 GTO's Avatar
Re: Long tube w/ true dual VS shorties and Ypipe?
To be honest, there are tons of guys on this board making big power through the standard single intermediate pipe. With up to 4" intermediate pipe and muffler (Mufflex setup), I wouldn't waste my time messing around with a dual setup that would add weight IMO.
Old Sep 11, 2004 | 10:22 PM
Tally_96_ws6's Avatar
Long Tubes all the Way. But have fun takin the Stock manifolds out. Just got done well almost done doin long tubes. 80% of the time was takin the stock manifolds out.
Old Sep 12, 2004 | 09:08 AM
PoorMan's Avatar
I did Jethot LT's and Summits universal X-pipe kit w/ 14" dynomax bullets. Pics in sig. It's the only way to go and cost me about $700 total.
Old Sep 12, 2004 | 09:42 AM
TS 95Z's Avatar
my duals weigh alot less than my old catback
Old Sep 12, 2004 | 11:28 AM
94Formula/TA's Avatar
Originally Posted by revkevs94Z28
Should I use 2/12
Man you would get some backpressure with those pipes.
Anyway as long as you dont care about emissions go with the duals.
Rich
Old Sep 12, 2004 | 11:44 AM
dust6928's Avatar
do some research on the subject and you will find that a single 3" pipe will have sufficient flow for an engine upto about 350hp. if you are making over that then go to a 4" (upto about 500hp) anything more is not really helping because it causes an over-scavenging effect. its kinda like taking a firehose and hooking it to your kitchen faucet, you will get some water out of it, but not enough pressure to do any good. i have gone through 4 different exhaust systems, over the 8 years i have owned my car, to get the right mix of flow and backpressure so i dont lose any bottom end and still retain top end.
revtime's Avatar
I run Hooker Jet Hot coated LTs and purple horny header mufflers.
My car is lowered a bit in the front with the Eibach drag launch kit and the headers have taken a little beating from the decreased ground clearance.
I love the true dual setup but it does require some compromises versus a stock location setup, I have rattles and the above mentioned ground clearance issues but I have driven the car everyday this summer so its not so bad I can,t drive it places but I do have to keep an eye out for speedbumps, severe dips in the road and things like that.
I love the way it sounds and I did pick up a very good performance increase from the LTs and true duals.
If you are looking for something you can just install and forget about then shorties and a Ypipe would be alot closer to that goal than a true dual setup.
Old Sep 12, 2004 | 07:33 PM
Not if you have an actual over-the-axle system it isn't. I wouldn't be caught dead with one of those half-assed "dual" systems that don't even go over the axle.
Old Sep 13, 2004 | 01:15 AM
revtime's Avatar
Then you would absolutely LOVE my half assed purple horny setup.
Personally, after having true duals I would not be caught dead with that mishmash of tubing running over the axle.
different strokes for different folks.
Old Sep 13, 2004 | 01:31 AM
jac6695's Avatar
How do Tri Y's with true duals compare performance wise?
Mar 18, 2015 06:31 PM
alphaauto
Jan 22, 2015 08:02 PM
Queens94z28
Nov 20, 2014 06:03 PM
RedLineRev
Jan 23, 2003 03:51 PM
