Long Tube question
Old Jun 17, 2003 | 06:04 PM
TenaciousZ's Avatar
Question Long Tube question
I just purchased Hooker LongTubes from Tbyrne motorsports (picking them up this week) Since they don't come with o2 bungs would I just have the shop that is gonna install them have to drill for the 02's? what else would I need? since i'm gonna delete the rear o2's.
Old Jun 17, 2003 | 06:17 PM
Brent94Z's Avatar
Super Moderator
You'll obviously need to purchase the O2 bungs but that's about it
Here is the most common location for the O2 bung.
http://www.bfranker.badz28.com/misc/o2fittings1.JPG
They point towards the center of the car.
Old Jun 17, 2003 | 06:30 PM
TenaciousZ's Avatar
thanks a bunch any idea what those would run for a pair?
Old Jun 17, 2003 | 06:34 PM
av8er's Avatar
How about putting the O2 bungs in the off road pipe? Then you wouldn't have to mess up those pretty headers.
JeffA
Old Jun 17, 2003 | 06:37 PM
av8er's Avatar
Thunder racing has them.
http://www.thunderracing.com/index.c...ategoryid=1052
Near the bottom of the page 5.50$ each.
JeffA
Old Jun 17, 2003 | 06:40 PM
Brent94Z's Avatar
Super Moderator
JeffA
For best readings, you want the O2 sensor as near to the collector (in) as possible. While it often works "ok" with the O2 sensors in the y-pipe, some have reported problems with a setup like this.
Old Jun 17, 2003 | 06:41 PM
TenaciousZ's Avatar
JeffA
Hmmm, that would work. thats a better idea. I noticed on tbyrne motorsports in the exhaust section that the mufflex ypipe for 249.00 comes with 02 fittings. Then they list it seperately and say it doesn't come with 02 fittings. which one s it?
Old Jun 17, 2003 | 06:43 PM
Brent94Z's Avatar
Super Moderator
Well, I have the Mufflex y-pipe and purposely drilled holes and installed O2 bungs in my headers. I now have spark plugs in my Mufflex y-pipe until I "redo" things and put an actual plug in there
http://www.bfranker.badz28.com/fbody/exh-0715_IMG.JPG
Old Jun 17, 2003 | 06:49 PM
av8er's Avatar
Beware the potential fit problems of the Mufflex Y-pipe. You might do a quick search before deciding to go with one. I have one on my JetHot LT's with the O2 fittings. I didn't use them because my LT's also had them in the collectors. As Brent said, you don't want to get the O2 sensors too far back but with the Mufflex they will only be maybe six inches further back than if you put them in the collectors. I would suggest a custom y-pipe with O2 bungs placed as far forward (up-stream) in the y-pipe as possible.
JeffA
Old Jun 17, 2003 | 06:51 PM
av8er's Avatar
Brent, a spark plug fit in there? Cool. That definitely brings up some ideas
I found some oil drain plugs that fit the O2 bungs. Worked out well and is nearly flush on the inside of the pipe.
JeffA
Old Jun 17, 2003 | 07:14 PM
Brent94Z's Avatar
Super Moderator
JeffA
The larger style spark plugs fit perfectly
Yeah, that was over a year ago... it was late and we were finishing up a dual header remove/install and the only place still open was Wal-Mart. My intention all along was to go get the proper plug and remove the spark plug. Sigh... intentions are always good but....
transam_388
Mar 15, 2015 11:53 AM
LT14LIFE
Feb 9, 2015 09:35 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
