Long Tube Pacesetter help!!!!
Old Jul 13, 2005 | 12:12 AM
blackztpi's Avatar
i've got my motor out of the car and decided to bolt up the headers for a pic or 2. well, i have the motor mounts bolted to the motor and the passenger side header wont eve come close to clearing the motor mount. stock motor mounts. i'm going to9 have to grind a good 3/4 inch to make it work. the drivers side is also going to have to be notched a 1/4 or 1/2 to clear the header pipe. what is going on, i thought the pacesetters were a bolt in and go???
Old Jul 13, 2005 | 12:18 AM
'94 Bad A Z28's Avatar
Re: Long Tube Pacesetter help!!!!
I put mine on with the motor in the car no problems. I had to loosen the steering nuckle for the driver side and it slipped right in from up top. For the passanger I had to go from underneath and grind down a little bit of the backing plate for the dust cover on the tranny (A4).
Old Jul 13, 2005 | 12:23 AM
blackztpi's Avatar
the actual motor mount bracket (the part that bolts to the side of the motor) is hitting. i'm hoping i got the right headers...!!! also, people recomend getting new motor mounts all the time with long tubes (which i already did)...what excactly does that help?
Old Jul 13, 2005 | 12:27 AM
No clue, I didn't have any problem like that. Sorry I couldn't be of more help.
Old Jul 13, 2005 | 12:32 AM
blackztpi's Avatar
as far as i know, pacesetter only makes one style of header for lt1. these act like they are not even the right ones. i have just a regular 94 m6 z28
Old Jul 13, 2005 | 12:46 AM
Built on Sin's Avatar
Yeah, you should recheck part numbers. No problems with the motor mounts with mine.
Old Jul 13, 2005 | 04:48 AM
Randy L's Avatar
From what I've read on other posts, the new mounts will prevent the common problem of the Y-pipe hitting the floorpan of the car...or something like that. It's a clearance issue that's supposedly fixed with new motor mounts.
Old Jul 13, 2005 | 08:49 AM
Feenix's Avatar
new motor mounts on the install is usually just preventative maintenance. Cause once you put headers on, you can't replace the mounts without either A) removing the headers again, or B) pulling the motor out of the car. Of course you'd just take the headers back off, but why not just replace them now with some urethane pieces to prevent needing to go back and do it later?
Old Jul 13, 2005 | 12:19 PM
89385formula's Avatar
Interesting issue you have there....My passenger side header rubbed slightly on the motor mount bracket as well. I did mine with the engine in the car...it went in without an problems, but it was touching it alittle. I put a pry bar in and made alittle ding and no more issues. Def check part numbers, because that doesnt sound right at all.
Kyle
Old Jul 13, 2005 | 12:25 PM
Loadre's Avatar
Post up some pics.
Old Jul 13, 2005 | 12:39 PM
Evil Eric's Avatar
ive never heard of this problem on an LT1. i want to see some pic's to
Old Jul 13, 2005 | 12:44 PM
blackztpi's Avatar
i wish i could get pics. i'll try somehow. the passenger side header is keeping the header from coming down onto where they bolt up. i'm going to try and notch the motor mount without hurting the strength, but it's going to need notched a good 3/4". i talked to pacesetter. they claim they only make 2 different headers for lt1 f-bodies...the lt's with AIR and smog, and the lt's without (race version, which is what i have). so i have to have the right header, but damn
Old Jul 13, 2005 | 03:46 PM
1993Fast_Z's Avatar
i am thinkin of going with these...could you guys tell me if they are SMOG Legal?
Old Jul 13, 2005 | 04:06 PM
SoloExceptional's Avatar
They do make a set with the AIR and EGR hookups on them, but you'll have to get a custom Y or X pipe with Cats on them
Old Jul 13, 2005 | 04:08 PM
1995greenTA's Avatar
My race style pacesetters are really really close to the motor mount as well. I would say within an eight of an inch on the passenger side. It is kind of scaring me because when the motor twists will it mash the primary?
