long tube install
Old Feb 9, 2007 | 08:48 PM
Maro Boy Ken's Avatar
long tube install
If i take my heads off will my headers go on easier? From the top?
Old Feb 9, 2007 | 09:28 PM
Razor_Blade's Avatar
Yes, but the headers might get in the way when you tourque down the outside bolts.
Old Feb 9, 2007 | 10:00 PM
12345678910's Avatar
why not do it from the bottom and save yourself the trouble from taking the heads off
Old Feb 9, 2007 | 10:20 PM
camarozz95's Avatar
I did both of mine through the top without taking the heads off
Old Feb 10, 2007 | 01:08 AM
2000GTP's Avatar
It will make it a little easier to get the headers in with the heads off, but as mentioned, it may then make it harder to get the heads back on. I would just tough it out and install them with the heads on.
Old Feb 10, 2007 | 10:58 AM
Fastblackcar's Avatar
Just take covers off, it'll give you just enough to slip it through.
Old Feb 10, 2007 | 11:03 AM
wrd1972's Avatar
Uh huh, valve covers off helps a lot.
It would be rediculas to pull the heads, damn that would be a lot of work for a header install plus those outside 7 bolts would be super hard to reach.
Old Feb 10, 2007 | 05:31 PM
97formulakid's Avatar
Lift it off the motor mounts and you should be fine. I didnt take the valve covers off and the Passenger side went in from the bottom and the driver side FELL in through the top. Oh, don't forget the steering shaft on the driver side.
Old Feb 10, 2007 | 07:41 PM
Im putting on my le2 heads/cam at the same time thats y i ask.
Old Feb 12, 2007 | 10:37 PM
are you pulling the whole motor out? if the motor is already out, lay the headers in the engine compartment and then slowly lower the motor into place without smashing the headers. after you have the motor bolted up, your headers will be laying right there waiting for you to bolt them up.
if the motor is already in, then you should be able to get them in there still without taking the heads or valve covers off. like i said I did mine like that and the driver side literally dropped into place while the passenger side needed a little work but it went in also.
Old Feb 13, 2007 | 07:18 AM
2000GTP's Avatar
I would just put the heads/cam in and then follow up with the headers. Just having the valve covers off will help a great deal.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
