Long tube heasders...Who has the best fit.
Old Oct 29, 2005 | 02:18 PM
wrd1972's Avatar
Still pondering going LT', but Im hearing bad things about fit. Collectors hitting the floorboards etc.
Who makes the best fitting headers for LT1, I want headers with y-pipe that will bolt up without having fitment issues.
Old Oct 29, 2005 | 02:26 PM
snakeatinZ's Avatar
Re: Long tube heasders...Who has the best fit.
Pace setter get my vote... No slip fit. Best headers for the money. They are cheaper than Jet hot.
Old Oct 29, 2005 | 02:28 PM
Cmr0z28's Avatar
My Pacesetters slipped right in.
Old Oct 29, 2005 | 02:50 PM
97WS6SCharged's Avatar
My Kooks weren't bad. The driver side I just had to unhook the steering shaft and it slid right in with the oil filter in place. The passenger side I had to unbolt the motor mount and tilt the motor for about 1/4" of clearance. My only gripe is the short starter bolt is a little bit hard to get to now, but once you know the trick it ain't bad.
1 3/4" stepped to 1 7/8" LT1 race header
Old Oct 29, 2005 | 03:03 PM
Z28WannaB's Avatar
Pacesetters. *beats the horse to a bloody pulp*
- Z28wannab
Old Oct 29, 2005 | 03:04 PM
2000GTP's Avatar
It seems unless you own an LS1, your long tubes are gonna bang the floorboard Otherwise, I installed the Pacesetter longtubes and the fitment was great but they slightly bang on the k-member a little bit, but this is due to tired motor mounts. Still, the quality of the headers is good and the price is very affordable.
Old Oct 29, 2005 | 04:52 PM
ChevyTuffD.A.'s Avatar
It seems to me that most issues people are having come from tired motor mounts. That or maybe the header has a small defect from the factory which causes it not to fit perfect. My buddy bought a set of the Pacesetter long tubes and the same set has been installed on 3 differant cars ( we seem to have a problem with all our cars not running at the same time so we borrow parts alot) and they installed just fine on the 3 differant cars. Peace, Dustin.
Old Oct 29, 2005 | 04:59 PM
JS_CZ28's Avatar
Just did pacesetters yesterday took 2hrs from start to finish... Best install ive had.
Old Oct 29, 2005 | 05:45 PM
wrd1972's Avatar
Where did you get them, how much and to the collectors leak?
Old Oct 29, 2005 | 10:30 PM
Bersaglieri's Avatar
My Hookers worked great, never a fit issue and went in suprisingly easy.
-Dustin-
Old Oct 29, 2005 | 10:41 PM
stroked383z28's Avatar
Pacesetter hands down. I just did the install a few days ago and there were no fitment issues whatsoever. Pacesetter has revised their headers to eliminate the fitment issues people have had with them before. I highly recomend putting in a set of poly motor mounts at the same time to avoid any issues with the headers hitting the floorboard.
Old Oct 29, 2005 | 11:37 PM
94sinister's Avatar
My Kook's don't bang the floorboard at all. Although I'm starting to suspect the loud ticking noise coming from my car is an exhaust leak at the slip-fit collectors.
Old Oct 29, 2005 | 11:59 PM
MentalCaseOne's Avatar
Ok I am going to Add the **New** Pace Setters to my Xmas list. Whats the part number and where to buy them from?
Where did you get the Motor mounts from? I was planninng of doing motor mounts and ditchin my tranny mount for a softer one after that.... Are the LS1 motor mounts interchangable? they have more HP how are the mounts holding up?
Marvin
Old Oct 30, 2005 | 01:06 AM
The part number for the coated race version (no air or egr) is 72C2239. I'll send you a PM for a good place to get them from. I bought the Prothane motor mounts part number 7-508-BL from Summit for $39.95.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
drptop70ss
May 4, 2015 08:22 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
