Long Tube headers OR Shorties
Old Jan 3, 2008 | 07:16 AM
yungin' w/a z28's Avatar
In your guys' opinion, what is better for the LT1? I am about to place an order and I'm not sure which I should get. Which is better? Which will I get more horsepower and torque with? Thanks....
Old Jan 3, 2008 | 07:25 AM
davidz28guy's Avatar
long tube ftw
Old Jan 3, 2008 | 08:43 AM
JohnnyPappis's Avatar
If your state allows it long tubes all the way.
Old Jan 3, 2008 | 08:49 AM
Javier97Z28's Avatar
Moderator
Uh... longtubes.
Old Jan 3, 2008 | 08:51 AM
Projectcam94's Avatar
Lts
Old Jan 3, 2008 | 09:18 AM
Jazsun's Avatar
If you have an aftermarket cam w/ more lift you have to go LT no question.
Old Jan 3, 2008 | 10:39 AM
Long Tube headers it will be....
Anyone have a suggesstion on brands and where to get the best prices?
Old Jan 3, 2008 | 10:51 AM
dangalla's Avatar
pacesetter, i recomend coated and dont forget the off road y
Old Jan 3, 2008 | 11:17 AM
MrCamu's Avatar
I've heard that the longtube headers advantage comes in high rpm's and in low and middle range rpm's there is not a big difference between shorty or longtube.
Correct me if I'm wrong...
-e- this was just a thought, half time comment ...
Old Jan 3, 2008 | 11:34 AM
Z-RATED94's Avatar
Longtubes, non emission type, if you can. Forget shorties, make believe they don't exist.
Old Jan 3, 2008 | 12:36 PM
reamo04's Avatar
pacesetter coated long tube, non-emission
i got mine from
texas-speed.com
but, basically all of our vendors carry them
Old Jan 3, 2008 | 12:46 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
If money isn't an issue, get Kooks. Try one of the sponsoring vendors for the best price. I got mine from MarylandSpeed.
Old Jan 3, 2008 | 12:55 PM
SS MPSTR's Avatar
agreed - excellent header.
Old Jan 3, 2008 | 01:07 PM
reamo04's Avatar
if you want something cheaper than kooks, but better than pacesetters, id look into
hedman, hooker, jethot
Old Jan 3, 2008 | 01:14 PM
Jazsun's Avatar
I belive this is true as well. At low RPM the speed of exhaust being pushed out is obviously not as high as higher RPM's, thus the exhaust can be more restrictive down low and not dampen power output.
Then again when your racing when are you at low RPM's? Maby the first 2 seconds of the race longtubes = mids, but after that its all longtubes.
