Lokar or Milidon?(Dipstick)
Old Jun 5, 2005 | 10:38 PM
Camaro4LifeSS's Avatar
I did a search and read that some people have had problems with the Lokar oil dipstick when reinserting it.I also read that some people have had the stick break off in the stoker motors which I will be doing in the future.Some people have said to spend the extra and go with the Milidon.Does the Milidon have the same problems or did they adress this?I was also wondering if Lokar fixed their problems and came out with a specific part # for our cars?Which one should I order?
Thanks in advance,
JE
Old Jun 5, 2005 | 11:13 PM
ibanez6rg's Avatar
Re: Lokar or Milidon?(Dipstick)
I think the Lokar looks good and is made with good quality, but it's a pain in the *** to get it in and out (on my setup).
Old Jun 5, 2005 | 11:37 PM
simple's Avatar
i find it easiest too twist the stick as i insert it (lokar)
can be a PITA too mount since it uses a header bolt
Old Jun 6, 2005 | 06:58 AM
Thanks for the info fellas.Anybody have any info on the Milidon stick?
Thanks,
JE
Old Jun 6, 2005 | 09:03 AM
89385formula's Avatar
I have the Lokar Dipstick on my 94 Z-28 and its really not a pain to use anymore. The first few times it was difficult but I got it within a minute. Now it slides right in after being on the car, and getting molded to fit with heat and use. Looks good too, i would buy it again.
Old Jun 6, 2005 | 09:21 AM
Loadre's Avatar
Lokars is the ****. Hard to put in at first but you get used to it. Just twist while pushing.
Old Jun 6, 2005 | 11:20 AM
CANTONRACER's Avatar
I had issues with my dipstick tube getting chewed by my old combo...so I have one disptick I measure with in the trunk...and one that sits in place in the dipstick tube.
Old Jun 6, 2005 | 04:37 PM
ibanez6rg's Avatar
That is true. I'm use to mine now-a-days, and its not too hard to get in and out. But, at the beginning...
Old Jun 6, 2005 | 10:06 PM
I'm certainly going to get the Lokar if I don't get any feed back on the Milidon stick.I wonder if the Milidon has any problems with reinserting the stick?Thanks for all the feed back on the Lokar stick.I definatly don't doubt any of you guys that say it's worth it.Just thought i'd check'em both out.
Thanks again,
JE
dolfan324
Jul 17, 2015 10:34 PM
jmadoll
Mar 3, 2015 10:16 AM
Prorac1
Jun 28, 2003 12:23 PM
Got-LT1
May 27, 2003 06:55 AM
Joe Brodman
Mar 30, 2003 07:55 PM
