lock tight on rockers?
Old Oct 6, 2008 | 06:43 PM
Mtxz453's Avatar
Everytime i open up the car, afterwards at least one rocker comes loose. They are comp 1.6rr's and I have tightened them down 1/4 past zero lash with the engine off method. I have also made sure the little nuts inside are tighened down very well, but still one always comes loose. Can i use lock tight on them? I was thinking about tightening them down 1/2 a turn instead.
Old Oct 6, 2008 | 06:54 PM
mdacton's Avatar
do not use lock tight.....
The wya I do them is say you want a 1/4 lash......tighten the set screw when you get to 1/16 then tighten the whole thing down anoth 1/16.....it will lock it down good
Old Oct 6, 2008 | 07:00 PM
slowride94z's Avatar
+2
that's the way we used to do dirt track engines
Old Oct 6, 2008 | 07:03 PM
mdacton's Avatar
Originally Posted by slowride94z
+2
BTW my math is off... should be a 1/8 turn but you get the idea
Old Oct 6, 2008 | 07:20 PM
nought+ nought = nought
Old Oct 6, 2008 | 11:55 PM
Mtxz453's Avatar
great idea, will do that tomorrow
Old Oct 7, 2008 | 09:09 AM
BUBBA's Avatar
Switch to ARP studs. Do the normal routine for adjusting the lash and then tighten the lock screw. It may work to tighten the adjusting screw and the lock screw at the same time, however I don't believe that is how you are supposed to to do it. The reason your adjusting nut is coming loose is most likely do to poor top threads on the studs. JMHO
realistyc
Jul 28, 2015 07:32 PM
88IROC_Z
Jul 22, 2015 11:38 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
