Llyod elliot Cam package?
Llyod elliot sells a cam package I beleve it's a 2LE. Like the cc306 cam and heads package. Anybody ever ran this package before. I have all bolt ons like 4:10 gears, 58 throttle holley, headers - shorty, no cats, loudmouth exhuast, smaller pulleys, k&N, maf sensor, lt4 knock. I have the lt4 hot cam with 1:6 rockers right now. The heads are stock. My camaro is a m6 94 lt1. If I get go for this package. Should I be able to beat a new z06 vette or 04 cobra supercharged. - Will this package put in high 11 low 12's.
Lloyd is doing my heads right now. I'm going with his LE1 heads with bigger valves. He has a few people running high 11s low 12s with his LE1 package so I think his LE2 package will put you in the mid 11s maybe better.
You should be able to pull an 01 ZO6 no problem and run relatively close to 02-04 ZO6's. Some of those ZO6's are touching 11's stock with great drivers. Stock cobras here trap 110-112mph and pullied ones run 116-118mph. I'd expect YOUR trap speeds in the 115-117mph range when tuned correctly.
When i was making 368rwhp/336rwtq I pulled a 12.5 @ 114mph with a baseline mailorder tune and a crappy 2.04 60'. I then played with the fuel regulator on the dyno to "simulate" leaning it out (since i didnt have a laptop to tune). i ended up with 383rwhp/353rwtq and I could have probably hit the 390rwhp with real tuning. From 2400-3000rpm I gained 30rwtq by leaning it out! In the end the peak numbers were 15rwtq/17rwtq, but its the low end that really increased. I dont doubt that i would have picked up another 2 mph with that new power and even more with a real tune. This was all with an XE230/236 114LSA and lloyd's stage 2 heads.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
