Lloyd or trick flow heads???
Old Jun 22, 2004 | 09:28 PM
lillbush5555's Avatar
I am in need of some decient heads. I have been looking and was wondering if Lloyds heads are better than the new trick flows? Or are trick flows better? I have a cc306 cam on a stock(trying to get $ for a 355 or 383) But here is a link to the trick flows...http://store.summitracing.com/search...D3042b010&y=16
Now you have to keep in mind that is for BARE heads I would spend another 170 to get valves..for a total of right around 1k. What is my better deal Lloyd or trick...Or are there anymore out there with a better deal?
thansk
matt
Old Jun 22, 2004 | 10:02 PM
kmook's Avatar
Advanced Tech Moderator
Lloyd's heads are going to make more power than a stock set of trick flows.
Old Jun 22, 2004 | 10:08 PM
LSUxBlake's Avatar
Yep, you should get lloyd's heads. Trick flows will need to be further ported to reach his numbers.
Old Jun 22, 2004 | 10:17 PM
amean94ta's Avatar
i say krs heads they outflow le's heads by alot and are more bang for the buck mine flow 271/230 at .600 at 28
Old Jun 22, 2004 | 10:20 PM
SnakeKilla's Avatar
What is KRS stand for?
Old Jun 22, 2004 | 10:24 PM
Spinner's Avatar
Dont start that again
Old Jun 22, 2004 | 10:42 PM
Kory 88 Iroc Lt-1's Avatar
your intake peak number is the same as most of Lloyds .600 numbers. your exhaust number is doctored. I have never seen a lt1 exhaust port that flowed that,without extensive welding. Lloyd flows his exhaust without a pipe. mine flowed 191 at .600 with no pipe.
Lloyds heads are a great bang for the buck. I would go with them again.
Just my .02
Kory
Old Jun 22, 2004 | 10:48 PM
Z-RATED94's Avatar
Listen to Kmook. Just call Lloyd and tell him what your looking for. He's a great guy and will do his best to help you with what you want to accomplish.
Old Jun 22, 2004 | 10:55 PM
Robs97Z28's Avatar
Lloyd, head will flow better. He can give a custom cam to match the the package you want. stages 1 2 3.... Trick flow heads are crap.
Old Jun 22, 2004 | 11:29 PM
amean94ta's Avatar
KERNS RACING SUPPLY
or krs machining for short
dont worry we will have some vids up soon
Old Jun 22, 2004 | 11:32 PM
kmook's Avatar
we have stage 1,2,3 and also get bullet cams custom ground to match
How about you stop advertising parts and/or services since your not a paying advertisor. I already edited your advertisements in the forum I moderate and would here to but I'll have to leave that to Brent. Thank you.
Old Jun 23, 2004 | 02:14 AM
5.0THIS's Avatar
if you're considering aftermarket heads, screw trick flow, go with AFRs they're proven, and offer more options in port size and more potential for flow
Old Jun 23, 2004 | 03:59 AM
jkipp84's Avatar
Another vote for Lloyd, he's got a heads and cam package for $1100. You'd have to spend a pretty good amount over the cost of bare trickflow's to get in the same power ballpark as that package. Also, the Trickflow's will lower your compression unless you get them milled down. Of course, this would be yet another additional cost.
Old Jun 23, 2004 | 05:09 AM
simple's Avatar
i wouldnt go that far
noone has really had a chance to use them yet (that most have heard of anyway) i would bet they are a very good alternative to AFR for quite a bit less money
Trick Flow makes some very good heads for Ford and GEN1 SBC motors, which LT1's pretty much are!
hard to beat Lloyds prices tho
Old Jun 23, 2004 | 06:36 AM
amean94ta's Avatar
you got it mooker
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
