Little Tick, valves?
Old Nov 12, 2006 | 11:39 PM
Gun5's Avatar
Well my mechanic said bring her back for another valve lash adjust on driver side and pass side..
i notice on cold starts i got a click click click (idle 1,100 and at 2,200 alittle faster) then after that it goes away once the car hits its operating temp of 170 (electric pump + waterwetter) it doesnt do it anymore really..
i imagine its just the valves that need adjusting and the fact that i drove it like 100 miles like this with a few WOT's didnt hurt it hopefully?? (before it started doing it noticably on start) like i said it goes away
Old Nov 13, 2006 | 07:53 AM
95LT1conv's Avatar
were they adjusted w/ the engine running? if not try that method. loosen them up one at a time until they click. retighten until the click goes away and then an additional 1/4 turn.
Old Nov 13, 2006 | 05:13 PM
Severous01's Avatar
check the exhaust gaskets. it sounds similar to a valve tick. or, get a screwdriver that's really big and touch it near where you think the tick is. place your ear on the handle end and listen. the sound will travel the driver to your ear. pinpoint where it's coming from.
Old Nov 13, 2006 | 06:06 PM
playswithcars's Avatar
>>> i notice on cold starts i got a click click click <<<<
Could be piston slap!
Old Nov 13, 2006 | 11:22 PM
Gun5's Avatar
ya its cold starts but its a valve noise.. once it heats up its gone basicaly or just runs for a bit its gone
Old Nov 14, 2006 | 07:05 AM
That's exactly how piston slap sounds. Only when cold, as block and pistons warm up and expand differently, the clearence decreases and the sound disapates. When it is happening, sounds like it might be coming from anywhere on the engine. I have had it with big blocks, small blocks and the LS 1 & 2 engines. LS 2 GTO and 6 ltr truck slap pretty good at initial start up. The truck, with case iron block, is especially loud for about 45 seconds and then settles down. Of course, dealers say this is normal and acceptable.
Lets us know exactly what you fine.
Old Nov 14, 2006 | 07:39 AM
Gun5's Avatar
well we are pulling some stuff off today to look at it gotta set the lash for valvs.. and check rockers and ****
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
