A little jumpy at stop signs
Old Feb 4, 2008 | 03:26 PM
darlandz's Avatar
Okay here is the problem. i got a 95 z28. So my car starts fine and everything is great and then once it is good and warm at normal operating temperature, i come to a stop sign and hold the brakes down pretty good and the cars rpm's are jumping and its starting to bother me. So what are the major spots for a vacum leak, or is it something else? the only thing i can think of is where i cut the spot for the gigantic tube out of the intake elbow, but i taped it really well.... i dont know though let me know. thanks
Old Feb 4, 2008 | 06:40 PM
30696bird's Avatar
Buy a new elbow.....tape ain't gonna get it! If that does not fix it maybe it's the MAP sensor. Just a guess.
Old Feb 4, 2008 | 07:39 PM
mrmint69's Avatar
I would check to see if your getting any codes. It could be a number of things so it might take some work. You should be able to find the problem without just buying new parts so i would go that route first.
Old Feb 4, 2008 | 07:48 PM
greenmachinedriver's Avatar
does the rpms still jump if you take your foot offthe brake and put it in neutral? if not your brake booster may be leaking.
Old Feb 4, 2008 | 10:18 PM
darlandz's Avatar
yes that is exactly how it is. i put it in drive and its like jump jump jump and then neutral is smooth as a bird. and why is that jump so hard once its warm though? and not so noticable when its cooler? o and just a quick question to throw in here also is there anything i can put on my belt to make it stop squeking. i bought a cheap belt at auto zone... maybe should've went with the more expensive one...
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
4586
Sep 27, 2015 01:55 PM
KYWes
Sep 26, 2015 08:49 AM
mark0006
Sep 14, 2015 12:35 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
