List of valve covers that truly fit over Jesel shaft rockers on LT1
Old Dec 15, 2007 | 08:08 PM
quickSS's Avatar
So far I have found 3 brands of valve covers that fit or can be made to fit.
Best fit:
GM Corvette composite
Modification required: Cut out the oil baffles surrounding the PCV hole.
Good fit:
ProForm (also sold as GMPP) medium tall cast centerbolt
Modification required: Grind inside of valve cover for more clearance.
Alternator modification needed, (move forward or relocate)
Ok fit:
Canton fabricated centerbolt valve covers
Modification required: Grind inside of valve cover at alternator notch for shaft clearance or grind rocker shaft bolt head short. Much taller than needed thus heater hoses interfere as well as wire-harness on B-body platform. Alternator interference in some cases on F-body platform.
Any others? I’ve heard that stock GM centerbolt covers can be made to fit. Anyone do that?
Karl Ellwein
Old Dec 15, 2007 | 08:19 PM
SS MPSTR's Avatar
I understand the Moroso cb covers clear with a little clearancing work.
Old Dec 15, 2007 | 08:24 PM
mdacton's Avatar
I don't see where they would need any clearancing at all as far as the rockers. They are huge inside, has a billet rails and the sides are welded to the ouside of that.....If your talking about the big fabbed ones.
Old Dec 15, 2007 | 08:32 PM
SS MPSTR's Avatar
those are the fabbed Moroso's right? nice pieces, for sure, and they claim that they clear all the valvetrain set-ups. the one's I mentioned are the one's I have, but for whatever reason, I cannot find mine on Moroso's site for the purpose of a link.
Old Dec 15, 2007 | 08:38 PM
mdacton's Avatar
these http://www.jegs.com/webapp/wcs/store...10002_24952_-1
I wonder why more people don't run those they look good
Old Dec 15, 2007 | 08:43 PM
SS MPSTR's Avatar
#68036 is what I have...although the logo looks a little different, but mine are about 4 years old already too. I ran 1.7's under these with a big *** cam with no issues after clearancing.
Old Dec 15, 2007 | 08:49 PM
rock1501's Avatar
I used the proforms they dont look so hot but they are cheap and do the job.I did nave to clearace them because I relocated the alternator
here is a pic
http://www.flickr.com/photo_zoom.gne...57603466117538
Old Dec 15, 2007 | 11:09 PM
Boosted_Z28's Avatar
I modified my LT-1 heads (Trickflows) by drilling and tapping them for these valve covers which would give you plenty of clearence for Jessel rocker arms:
Old Dec 15, 2007 | 11:29 PM
BIGCOWL-IMP's Avatar
I have the B&B Fabrication valve covers that fit over my T&D shaft mount rockers. I had them made about 3-4 years ago.
They look dented in the pic but there not.
Old Dec 16, 2007 | 02:04 AM
lt1rx798's Avatar
i have a cheap aluminum set from ebay... they were bare aluminum. i wanted black so i painted them, but you can see the design. i think i paid $30-40 for them, and no mods were needed.
http://i64.photobucket.com/albums/h1...8/IMG_0577.jpg
http://i64.photobucket.com/albums/h1...8/IMG_0578.jpg
Old Dec 16, 2007 | 06:27 AM
quickSS's Avatar
so basically all of these are fitting over Jesel shaft rockers right?
I see that alternator moving or modifying is needed for all of them, (with the exception of the Corvette composites).
Anyone have a valve cover that fits the Jesels and does not require moving the alternator?
Karl
Old Dec 16, 2007 | 06:34 AM
quickSS's Avatar
MDAction, do you use these? Do the clear the pushrod side of the Jesel rockers? they look like a good candidate for clearing the alternator.
Karl
Old Dec 16, 2007 | 09:06 AM
mdacton's Avatar
Karl
No, Mine is the pic above with the fabbed ones.
I'm pretty sure CSJTA is using those with jesels.....shoot him a PM
Old Dec 16, 2007 | 10:05 AM
CSJTA's Avatar
I'm using these valve covers with Jesel SS, you will have to modify the inside of the vc, they will work with the alt in the factory position, but you will have to modify the alternator
Old Dec 16, 2007 | 12:54 PM
rock1501's Avatar
I have the jesel ss rocker also had to take out the baffle inside to clear but it is an easy fit.I understand if you dont relocate the alternatore you just have to grind off the ear and it will clear
