List of parts for cam swap and refresh
Old Jan 22, 2007 | 06:49 PM
  #16
truedualws6's Avatar
Originally Posted by buzz12586
Do you have the part number for those locks?? I was just using the ones that comp cams suggested on their website.
You will need to switch to the 10 degree retainers to use the +.050
super locks. The part numbers are:
795-16 retainers
614-16 locks
Old Jan 30, 2007 | 12:57 AM
  #17
Mortify's Avatar
sticky this.
Old Feb 1, 2007 | 06:16 PM
  #18
buzz12586's Avatar
Yea it would be nice to have it stickied.
Old Feb 25, 2007 | 09:07 PM
  #19
69z-28's Avatar
the 7 degree retainers are for the 918s but it doesnt show that the 10 degree retainers work with the 918s also....
http://store.summitracing.com/partde...5&autoview=sku
Old Feb 27, 2007 | 04:28 PM
  #20
Purplemaroz28's Avatar
Check your rods, this same thing happened to me and after a week back together it spun a bearing, one of the rods was bent, im guessing from the water pressure. just a word of advice.
Old Feb 27, 2007 | 04:40 PM
  #21
buzz12586's Avatar
Its getting all new forged pistons and rods.
Old Mar 13, 2007 | 04:44 PM
  #22
snakeatinZ's Avatar
Your cart contains... If you have a coupon code, enter it here:
Qty Part # Product Amount Total
63-26918-16 Comp Cams 26918 Beehive Ovate Spring, set of 16 $179.99 $179.99
63-795-16 Comp Cams 10 degree Steel Retainer for Comp 26918 valvespring. $49.95 $49.95
63-613-16 Comp Cams 11/32 10 Degree Machine Steel Locks, set of 16 $24.99 $24.99
Order Total: $254.93
Is this the right stuff? I cant find the 614-16 locks?
Old Apr 10, 2007 | 06:46 AM
  #23
snakeatinZ's Avatar
Anyone???
Old Jun 15, 2007 | 06:50 AM
  #24
Greg88's Avatar
Hey, BUZZ12586, did u ever get the part number for the .50 locks? if so can u let me know what it was, also wondering if you had his set up in your car now and how it works??
Old Jun 15, 2007 | 05:01 PM
  #25
buzz12586's Avatar
I have the setup in my car now and its running great. No dyno or track times yet though. The part number for the .50 locks is 614-16.
Old Jun 19, 2007 | 06:46 AM
  #26
Greg88's Avatar
I was wondering if the state you're in requires you to get an emissions test or whatever you call it, if so does the car pass? Also, you wouldnt happen to have any videos or the car at idle would you? if so email them to me at vandenberg_greg@hotmail.com, that would be greatly appreciated
Thanks, Greg
Old Jun 19, 2007 | 09:01 AM
  #27
buzz12586's Avatar
Yes it did pass emissions but I do still have the stock manifolds on. We weren't able to put the headers on in the time I had left in the shop so its probably 30-40hp short and its quieter at idle. Sorry, don't have any videos.
Old Jun 19, 2007 | 03:48 PM
  #28
Greg88's Avatar
So, im assuming that the part list u recommended at the beginning of this thread is all the same, except for the locks you used the .50's...i was just wondering i see in the list of parts there, u said piston rings, is that the stock piston ring size? or is that bored out and same with the main bearings? you didnt turn ur crank correct? and on more thing, did u have to get the high rise valve cover's??...
Old Jun 19, 2007 | 08:50 PM
  #29
buzz12586's Avatar
I ended up having the crank turned so I had oversized Rod and Main bearings. Block was bored out .030 so I had to get larger pistons and rings.
Old Jun 19, 2007 | 10:59 PM
  #30
CrazyJim's Avatar
Member
So what's the total build cost?
