liquid coming out of my header collecters.
I had a leak with the slip fits on the header collecters and y pipe so I tightened it up and started the car and noticed a few drips of a clear orange tint liquid comen out this is the second time I noticed it since I put the headers on what do you think it is. They are coated pacesetter headers. off road y I have egr and air hooked up.
The only way eh....
You can also get coolant coming out of your exhaust if you have porting issues in your exhaust port.
I would check your coolant levels and you never know...maybe it is condensation and rust?
It seems that its leaking and it smells like coolant burning for a while now. 2 weeks ago I lost power stearing because some how coolant got on my belt and wasnt spinning the power stearing so now its all starting to add up. It must be just leaking alittle and the 1 time it leaked alot and stoped The car wasnt even warmed up when that happen. I just need to fing where the coolant is coming from. What do you think.
Yea its weird, Im thinking who ever owned the motor before mite have put in a leak seal crap and it slowed it down or something. But that all I can think of I really hope its not a head gasket The motor has 56k and I dont realy beat it and I maintain it very well.
have you checked the oil for water?
Do a search for blown head gasket and see if any of the smyptoms they have are the same as yours
Like oil in the coolant or coolant in the oil and so on.
Any overheating problems?
Since i seems like you do not have a lot of knowlege about the lt1 maybe it would be best to ask around and find a local shop that works on LT1s and take your car to them.
no white cloud of smoke. As for the knowlege On lt1 trust me no1 in Pittsburgh realy has any idea about an LT1 or want to work on it. I wouldnt but you cant even get plugs and wires on this car changed they take it somewhere else. I know a little bit I put the LT1 in the car it was A V6
Pressurize the cooling system with the engine off and cold, then with the engine warm. DOes the gauge drop?
All cars will condensate out of the exhaust. Do you have to add coolant? The leak on the drive belt, is it running down the header tube when cold?
Does it have an engine miss? If not, you do not have a blown head gasket into the cylinder, which is the only way coolant can get out the exhaust. Pull the plugs and read them, will also tell you if coolant is in the cylinder.
David
David
