In line check valve?
Old May 7, 2006 | 08:50 PM
Spitfire557's Avatar
I read somewhere that there was a check valve of some sort built in our fuel lines, is this true? The check valve maintained pressure at the fuel rails while the car is shut off. My car doesn't like to start up when it's cold, so I'm starting to think that my "check valve" may be shot, because I have good fuel pressure at idle/WOT, indicating my fuel pump is still good. I checked my parts manual, and can't find any part number's for this check valve. Anybody know the technical name for it? Thanks!!!
Old May 7, 2006 | 08:57 PM
Re: In line check valve?
There is a check ball internally in the pump. You need to monitor the pressure after the engine is shut off. Even still, a leaky injector can cause the rail pressure to drop.
Old May 7, 2006 | 09:04 PM
I have a new fuel pump sitting in my garage. Maybe I'll just take the plunge and replace it. I don't think I have any leaky injectors, I would be able to smell that, right?
Old May 7, 2006 | 09:09 PM
I doubt you could positively determine a leaky injector by smell. There are ways to test fuel pressure problems.
Old May 7, 2006 | 09:20 PM
When I did the plugs 500 miles ago, they were all evenly colored, none were different from any other. I might just do my fuel pump anyway, been dying to try out the trapped door method!!
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
