Line Bored Timing Chain???
Old Dec 8, 2003 | 02:01 AM
chesee48's Avatar
Question Line Bored Timing Chain???
I was told that i needed a line bored timing chain set for my 383 shortblock...
I might have mis understood what he was saying or he couldve been wrong.
I just wanted to know if anyone else has one on their setup or can explain what he was talking about in better detial?
Old Dec 8, 2003 | 02:06 AM
sssalah's Avatar
If you line bore your mains then there would be some slack in the stock length chain, there are special shorter chains for that purpose.
Old Dec 8, 2003 | 02:11 AM
S.J.S.'s Avatar
Never heard that before. Regardless if you line bore the mains...the end of the crank that the gear goes on is still the same size and needs to go out the same hole. I just built my 383 and threw it in with the LT4 extreme duty set. Got 900 miles on it so far. Sure he didn't say you'll need to line bore it (the block) and a timing chain set?
I'd like to know because that means I'd better go in and fix it.
Old Dec 8, 2003 | 03:33 AM
chesee48's Avatar
sweet, thats what thought. thanks!
Old Dec 8, 2003 | 05:11 AM
S.J.S.'s Avatar
WAIT...WAIT...WAIT.... Will soomeone tell me what does align boring your mains have to do with slack in the timing chain??????
I tell you what cheese. When you find one let me know.
Old Dec 8, 2003 | 05:16 AM
slopokrodrigez's Avatar
If you align bore and take too much material off the block side, the crank will be shifted up toward the cam and "loosen" the chain. A good shop doing align bore like the one that did mine knows that you have to take off most material out of the cap and very little off the block so as to not creat such a problem. Why, because there is no "shorter" chain available.
Think about it. The teeth on the 2 gears are always in the same place. What we call pitch. If there were shorter chains available, they would have to be a different pitch since you just can't leave out one link. Leaving out 1 link would make the chain too short. If the pitch of the chain changes then both gears would have to be changed as well. There is no one that offers such a kit.
Old Dec 8, 2003 | 05:35 AM
S.J.S.'s Avatar
Thanks Slowpoke.....I was waiting for someone to chime in. Either way...if you do it wrong the block is useless.
Old Dec 8, 2003 | 08:35 AM
CSJTA's Avatar
There are shorter chains available, atleast for the standard small block.
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
