Limiting factor
Old Jun 12, 2005 | 05:42 AM
69vette's Avatar
Limiting factor
Ok, heres the parts of my 383 that i just finished up. I was wondering how big of a shot i could run and what is the real limiting factor on that. Also what na/nitrous times do you think i will be running through a 9" with 4.30 gears, m6 trans. ok heres the list: street twin, le3 heads/cam, eagle h beam 6" rods w/ L19 bolts, lunati forged 383 crank, srp 138103 forged pistons, zero decked block, sheet metal intake with direct port fittings(don't have the nitrous set up for direct port yet, just the nx wet kit), block half filled, splayed mains, 58mm tb, 37# injectors, bigger fuel pump, jet hot long tubes, true duals,bmr k member, bmr upper and lower a arms, agx shocks, v6 rear springs, lower springs in the front, battery in the back, basically got all the supporting mods for the . thanks for your time...i'm just trying to see what you all think..ready to get my car to the track after i get the paint work finished up...
Old Jun 12, 2005 | 06:02 AM
ZMaster's Avatar
Re: Limiting factor
Well, I"m no expert at this, but what's your ring gap? Did you tell your machinist that you were going to load her up on juice, or is it a n/a setup? If you didn't tell him, it might be set up all motor. AFAIK, if you don't run a large enough gap with a big shot, you can end up breaking the ring lands when the rings expand. Don't take my word however, like I said, I'm no expert on this.
Ian
Old Jun 12, 2005 | 04:32 PM
69vette's Avatar
Re: Limiting factor
yeah it was mainly set up for na.
Old Jun 12, 2005 | 06:13 PM
1racerdude's Avatar
Re: Limiting factor
Guys run 200 shot on stock short blocks and completely stock engines. As long as ya pull enough timing and use a wet kit and have enough fuel pump all to prevent rattling it ya should be fine up to a 200.It also has to be tuned for the hose by somebody that KNOWS what they are doing or ya WILL hurt the motor.
Fat is happy on a NO2 motor.
Old Jun 12, 2005 | 09:27 PM
69vette's Avatar
Re: Limiting factor
yeah i'm just wondering what would limit how much the motor can hold. I talked to the guy who assembled it today and he set up the rings to run nitrous he said. I forgot all about it..i have soooo many projects going on right now. I was thinking that the main hold back to running a big shot would be the fact that its not direct port.
Old Jun 12, 2005 | 09:31 PM
1racerdude's Avatar
Re: Limiting factor
Put bigger injectors,more pump,and a butt load of hose-300- and a better cam, ya could run in the 8's with traction.
Old Jun 12, 2005 | 10:30 PM
69vette's Avatar
Re: Limiting factor
what size injectors? pump is already good enough for any size shot. what cam is better than the one bret designed?
Old Jun 12, 2005 | 10:34 PM
1racerdude's Avatar
Re: Limiting factor
Did Bret make it for NO2?
42# injectors to not have to run the pressure so high
Old Jun 12, 2005 | 10:48 PM
69vette's Avatar
Re: Limiting factor
bret made it for na so i guess that will hurt a little. If i were to switch over to je pistons from the srps woudl that be benificial?
Old Jun 12, 2005 | 10:51 PM
69vette's Avatar
Re: Limiting factor
sent you a pm 1racer. thanks for all your help.
Old Jun 12, 2005 | 11:28 PM
1racerdude's Avatar
Re: Limiting factor
Why do you want to change pistons??
Old Jun 12, 2005 | 11:30 PM
69vette's Avatar
Re: Limiting factor
no reason, just thought that the je's would be better with the notrous considering they are a better alloy.
Old Jun 13, 2005 | 07:59 AM
Re: Limiting factor
If I had to pick a "limiting factor", it would be the compression height on the pistons, due to the 6" rods. With a nitrous piston, you want a thicker crown to take the abuse, and you want to drop the ring pack down farther from the top of the piston, to keep the top ring out of the heat. Do that and your wrist pin it way up into the ring pack.
Old Jun 13, 2005 | 09:49 AM
69vette's Avatar
Re: Limiting factor
so if you were building a nitrous motor then it would be better to stick with a 5.850 or 5.7 rod. correct?
Old Jun 13, 2005 | 12:17 PM
Re: Limiting factor
Click on my "Detailed Mod's List".... you'll see exactly what I'm running with a 300-shot.
