Lightweight battery
Old Nov 23, 2002 | 01:09 PM
canbaufo's Avatar
Question Lightweight battery
I read something about a 13lb battery (Dyna or something) ....is that much lighter than a typical battery? Anything I can do to lighten up the front end can help with traction and handling some. What are your opinions on whether or not it's worth it to move the battery to the trunk? Most people say it isn't worth the trouble because it's such a small increase in traction. You'd think it would make a big difference if placed right over the right rear tire though ....no? Where can I get one of these lightweight batteries and does it have much cranking power?
Old Nov 23, 2002 | 10:06 PM
AlexA's Avatar
Read this :
http://www.stealth316.com/2-dynabatt.htm
I wouldn't relocate the battery as you have to add weight just to route large gauge wires to the back of the car. I would imagine putting some money into your suspension would help more - Spohn/BMR torque arm, LCA, PHR, V6 springs, Nittos/DRs....
If you are thinking about weight reduction :
http://www.ls1tech.com/ubb/cgi-bin/u...5;t=000021;p=1
and
http://www.bfranker.badz28.com/fbody/weights.htm
-Alex
Old Nov 23, 2002 | 10:53 PM
canbaufo's Avatar
Question
Thanks for the info. Does anyone here actually use these dry cell batteries? How practical are they really (without having to read all of that technical stuff). If it would require a lot more TLC than a regular battery and/or not last nearly as long I'm not interested.
Old Nov 24, 2002 | 08:29 PM
Camaro SS's Avatar
I run a Hawker Genesis G16EP which is the same as the Dynabatt but only $69. It works great. I've had it for about 6 months now and have not had a problem cranking my 11.1 comp 396. I did have my stock battery relocated to the rear. I moved this small battery back up front. The total weight saved with the new battery including the 0 awg wire that was run to the rear of the car and the battery box in the rear was 33.5lbs. Not a bad deal at all for $69.
Old Jun 2, 2003 | 05:06 PM
Dragon Racing's Avatar
Sorry to bring this old post back up, but where do you guys get your Hawker batteries at?
Old Jun 2, 2003 | 05:13 PM
Camaro SS's Avatar
Try here:
http://www.gotbatteries.com/
Old Jun 2, 2003 | 06:02 PM
Did you have to get anything else for that battery to work with our cars? Also, how did you mount it since it's alot smaller then a regular battery? Thanks for the help!
Old Jun 2, 2003 | 10:12 PM
Camaro SS's Avatar
Shoot me an email and I will send you a couple of pics of the battery installed.
Old Jun 3, 2003 | 01:50 AM
blksunshine's Avatar
could you send me some pics as well
jdelgado22@hotmail.com
Old Aug 10, 2003 | 07:04 PM
94bird's Avatar
Did you have to use the SAE battery terminal set they also sell for about $10? The Hawker posts don't look like a normal post for what I can tell.
Old Aug 10, 2003 | 09:55 PM
Camaro SS's Avatar
The battery just has threaded inserts rather that posts. You could get the screw on type posts. All I did was use bolts that threaded into the battery and put new ring terminals on the battery cables. Tighten it all up and it's good to go.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
football4life
Oct 4, 2015 07:48 AM
karpetcm
Sep 29, 2015 10:08 AM
jackpawt883
Sep 10, 2015 08:53 PM
