Lightup Spark Wires
Old Sep 7, 2003 | 10:08 PM
Wildwill532's Avatar
Lightup Spark Wires
This is on a 91 grand pre le, my friend was driving and the car shut off and we went to start it, it sounded like it was missing, i reved it up and i seen 4 wires lighting up blue and 2 big sparks, well all the wires looked fine nothing cut or cracked, we had it towed off what do you think could be wrong@
Old Sep 7, 2003 | 10:21 PM
Anderson's Avatar
Re: Lightup Spark Wires
I'd say change the wires anyways, and keep them away from hiting the exhaust.
Old Sep 8, 2003 | 02:03 AM
browneye97ss's Avatar
Just because you cannot see any defects with your eyes does not mean that there are not any. The easiest way to know if your wires are bad is doing exactly what you said you did. Start the car up in a dark location and look under the hood. If you see pretty lights than it is time to change the wires wether you can see cracks in them or not.
Old Sep 13, 2003 | 01:10 PM
THE PROBLEM WAS A BAD FUEL PUMP, hope this helps someone else out there with the same type problems!
titanthomas
Apr 18, 2015 11:44 PM
greenzee28
Mar 26, 2015 09:13 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
