lifters
Old Sep 10, 2008 | 07:11 AM
curtis75's Avatar
lifters
Is there an advantage to using LS7 lifters over the stock ones? Do you have to modify anything to use them?
Old Sep 10, 2008 | 05:57 PM
95Blackhawk's Avatar
You can read a lot of stuff on the LS7 lifter and why people use them. I just thought if they are used in the LS7, they should be good for my LT1.
Need to double check your pushrod length. Cup is a little different than stock. I think shallower.
Further, they are just as cheap as any other lifters out there.
Old Sep 10, 2008 | 05:59 PM
Sinister95Z's Avatar
The LS7's are a better design than the stockers that came in the LT1 engine. They will drop right in without any modification. It is always a good idea to check for correct pushrod length though. With my recent cam swap, stock length PR's worked perfect and I also used the LS7 lifters.
As far as I know, the stock LT1 lifters are not even available anymore. The replacement GM part number for the LT1 engine is now the LS7 lifter.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
