Lifters
Old Aug 25, 2005 | 04:48 PM
93 4mula's Avatar
Lifters
Well Ive been reading all the bad comments about these Comp R lifters and Im glad I searched before I bought them..Im in the process of buildilng a 383 going have to LE3 heads on it. I have the Crane Cam # 109651. What lifters would yall recommend getting? Would OEM be fine? I dont want to spend all that money on Comp R's and they crap out on me. Does crane make any good lifters?
Old Aug 25, 2005 | 05:09 PM
Z95m6's Avatar
Re: Lifters
OEM should be fine, i'm running them with my BRE cam after my comp R's blew up.
Old Aug 25, 2005 | 05:18 PM
93 4mula's Avatar
Re: Lifters
Man you would figure they would do something about this after all these people that have had problems with them. Any other lifters out there beside comp that are any good? Also any power loss from running OEMs besides aftermarket?
Old Aug 25, 2005 | 05:30 PM
JustNO's Avatar
Re: Lifters
What is your springs? If beehives, get OEM lifters.. Its all about springs.. For example if 977 springs are your choice (more pressure) I would go with Morel lifters.. Very expensive, but top notch quality..
So less pressure springs >> OEM lifters (and a rev kit)
more pressure springs >> Morel lifters (no rev kit required)
Old Aug 25, 2005 | 06:00 PM
asudecat's Avatar
Re: Lifters
What is the part # on the Comp R Lifters??
is it the 875's???
If so I guess im screwed, cause those are the ones i purchased.
what's the deal with them blowing up??
Old Aug 25, 2005 | 06:05 PM
Z95m6's Avatar
Re: Lifters
is it the 875's???
875's are the R's and the 850's are the OEM replacements.
Old Aug 25, 2005 | 06:07 PM
asudecat's Avatar
Re: Lifters
well hell!
so what's the big deal with these lifters??
or are you guy's gonna make me do a search?
Old Aug 25, 2005 | 06:21 PM
Z95m6's Avatar
Re: Lifters
well hell!
Do a search and look at the pics of blown up lifters. I've personally broke, or cracked 9 of the retaining clips in my R's.
Old Aug 25, 2005 | 06:27 PM
ktg's Avatar
ktg
Re: Lifters
Just replaced my crap comp-r's with cranes. No problems so far.
Old Aug 25, 2005 | 07:05 PM
93 4mula's Avatar
Re: Lifters
Which cranes did you run? How come the comp r's blow up?Also any power loss from running OEMs besides aftermarket?
Old Aug 25, 2005 | 10:55 PM
93 4mula's Avatar
Re: Lifters
Old Aug 25, 2005 | 10:59 PM
NJLT1SS's Avatar
Re: Lifters
Im replacing a Comp R that I busted the clip off. I have a set of Morels soaking in oil waiting to go in. I think this weekend when I do the swap, I will take some side by side pics of the Morels, Comp R's, and stockers. Not just pics of the outside, but also of the internals, so this way people can see the difference for themselves. My work is already a 1/3 of the way done, as the Comp R took itself apart already.
Nick
Old Aug 25, 2005 | 11:02 PM
Blownbird355's Avatar
Re: Lifters
R stands for racing. Comp says not to use them on the street.
Old Aug 25, 2005 | 11:20 PM
tardy007's Avatar
Re: Lifters
Here as some pics of my experience with comp r (in my sig)
Old Aug 26, 2005 | 03:15 AM
93 4mula's Avatar
Re: Lifters
So is there any difference in power when running oem's besides an aftermarket? Also was exactly is a rev kit?
