lifter recommendations?
Old Apr 8, 2003 | 01:11 PM
CGrant's Avatar
What lifters should I use for a cam something like a CC306, or a 230/236, Along those lines.
What lifters do you guys recommend?
Old Apr 8, 2003 | 02:13 PM
1fast95Z's Avatar
I'm using the stock lifters with my 306. Works fine. I see no reason to change the lifters unless they're worn out/damaged/etc.
Old Apr 8, 2003 | 02:29 PM
95CamaroZ-28's Avatar
I'm running Comp OEM lifters with my XE 230/236. I have some Crane OEM lifters in the box that I need to get rid of if you're interested. I was going to use them, but they took 3 months to get to me so I ordered the Comps.
Old Apr 8, 2003 | 03:34 PM
ltlhomer's Avatar
Someone just posted that the comp 875-16's (comp r's) are available once again. Might wanna consider those. Personally, I went with the GMPP lifter kit.
Old Apr 8, 2003 | 03:39 PM
Don 97 SS's Avatar
I just installed a set of Comp oem replacement lifters P/N 850-16 for about $200. My oem lifters with a mild Crane cam crapped out recently.
9t4lt4z28
Oct 2, 2015 10:28 AM
Beave2780
Sep 23, 2015 12:37 PM
Z Power
Sep 19, 2015 11:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
