Lifter Preload?
Old 02-16-2007, 10:56 AM
kline454's Avatar
Lifter Preload?
How much preload should i put of my lifters? I have cc306 with new gm lifters and 1.6rr, right now im running about 3/4 turn,
Thanks kyle
kline454 is offline
Old 02-16-2007, 11:12 AM
BUBBA's Avatar
You will probably get several different answers, however, I believe the factory sets them around 1 turn on the stock lifters. Most recommend 1/2 turn and many recommend even less.
Since everyone has a different feeling for 0 lash, one really doesn't know precisely how much preset they have.
If you believe you have them at 3/4, then shouldn't be any problems unless they are too noisey and snuugging them another 1/8-1/4 quiets them up more.JMHO
BUBBA is offline
Old 02-16-2007, 11:27 AM
Mauiguyy911's Avatar
I also do 3/4 turn, but they did seem like a couple came loose a couple hundred miles later so prob going to do what Bubba said, extra 1/8-1/4 and see what happens
Mauiguyy911 is offline
Old 02-16-2007, 11:38 AM
gitsum's Avatar
I go 1/2 a turn and tighten the polylock, then I go another 1/8 of a turn to make sure it doesnt loose up.
gitsum is offline
Old 02-16-2007, 12:51 PM
kline454's Avatar
ok thanks im going to keep doing it the way I have been.
kline454 is offline
Old 02-16-2007, 02:36 PM
Joe B's Avatar
(Just my experiences here)....So far Ive experimented with everything from 1 turn lifter preload.....all the way down to "true zero" lifter preload.....Each of my tried settings were driven for a number of weeks....the closer I got down to zero (like Im running now) the more the power picked up above 5500 RPM's(power that could "easily' be felt).......Hydrolic lifters just love to pump up at high RPM intern never letting the valves close all the way to trap cylinder pressure like it should(among other reasons)..........And also, (On mine) the valvetrain noise is really no different than setting them with gobs of lifterpreload...and It really shouldn't be... Having zero lifter preload (if set just right) still has no space(just like a preloaded lifter)........Joe
Joe B is offline
9t4lt4z28
10-02-2015 10:28 AM
Z Power
09-19-2015 11:19 PM
Daluchman1974
09-11-2015 06:12 AM
08-24-2015 06:41 AM
Quick Reply: Lifter Preload?
