lifter noise
Old Mar 9, 2007 | 10:14 PM
lr383's Avatar
lifter noise
Hope you guys can help with a problem I having. My sons ta has lifter noise that has gotten worse over the last month. These are comp rs but have not had trouble for a year with them . I have always set them at 1/8 turn and ever had this kind noise. Just pull the intake off to check for clips broken but none of them where broken.We sound like solid lifters. This is with a hot cam and Le 2 heads.
Old Mar 10, 2007 | 12:22 AM
deepstage69's Avatar
One lifter or several, I had one on my LT1, that clacked, rattled. I have read other lt1s have done this too, but this is stock cam and lifters.
Here is what it was.
Old Mar 10, 2007 | 09:34 AM
2000GTP's Avatar
Are you positive it is a lifter noise, or could it possibly be the noise of a small exhaust leak?
Old Mar 10, 2007 | 09:36 AM
lr383's Avatar
Thanks for the relpy. I was thinking it kinda looks like v.float what rpm did you run up to? have not taking the lifters out but I will to check the cam . the picture is worth a thousand words.
Old Mar 10, 2007 | 09:42 AM
lr383's Avatar
No it coming from the v. covers
9t4lt4z28
Oct 2, 2015 10:28 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
rideordie
Sep 7, 2015 08:22 AM
