lifter load
Old Jun 5, 2007 | 08:39 AM
immortalmack's Avatar
lifter load
I'm doing head gaskets (which a gallon of water was in a few cylinders) and in trying to loosen nuts to get he rods out I had to ****in crank some gut to get the nuts loose. Now are those nuts suppose to be that tight?
Also while I have my heads off. If I wanted to switch to roller rockers do I just give them to the shop that's checking my heads to put on and what else will have to change if I switch to roller rockers?
Old Jun 5, 2007 | 09:07 AM
The Engineer's Avatar
First, you'll need the "self-aligning" (S/A) RRs if you don't add the push-rod guide plates. Also, the 1.6 ratio RRs provide a nice performance improvement.
My recommendation is to go with the Crane Gold S/A, 1.6 RRs. They come with new poly-lock nuts (much better than factory) and will bolt on without any problems. Also, they will fit under your factory valve covers without any modifications.
Make sure the 0-lash adjustment is set correctly (1/4 to 1/2 turn preload).
WD
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
form94
Sep 23, 2015 07:30 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
