Lifter to blame... need new ones
Old Oct 10, 2005 | 10:59 PM
96LT1TX's Avatar
I have the comp r's and instead of listening to this damn noise in my motor every few runs at the track (the top of the lifter where the pushrod came off again, this is the 2nd lifter to do it) I am changing my lifters. I was wondering who has found some GOOD lifters that are GOOD for adjusting rr's while the car is running and also ones that are easy to find 0 lash with (comp r's were not). I have heard the morrels, anyone know where to buy them/if they are good?
thanks again
Old Oct 10, 2005 | 11:18 PM
69gto96z's Avatar
Re: Lifter to blame... need new ones
I am not sure of where to get em, but I have heard the Comp ones suck.
Old Oct 10, 2005 | 11:57 PM
Z95m6's Avatar
just run OEM lifters. If not i do have about 5-7 comp R's i'll sell you. The rest of my set blew up.
Old Oct 11, 2005 | 01:05 AM
96LT1TX's Avatar
what power level do you need more than a stock replacement type lifter and what is the advantage of anything other than OEM? I have a somewhat mean cam, just want all the insurance I can get... and I ended up messing it up more =/
im thinking crane or morel stock replacements???
Old Oct 11, 2005 | 01:14 AM
will62085's Avatar
oems are fine for you setup, but i ran the comp r's on the same cam as you, and never had a problem, they were always noisy, but i didnt really care, and the comps are goin back in my new motor, and again, at 0 lash
Old Oct 11, 2005 | 01:17 AM
SStrokerAce's Avatar
OEM lifters are great lifters, only thing worth it over that are Morel's. They are pricey but are the best out there.
Bret
Old Oct 11, 2005 | 03:50 PM
96LT1TX's Avatar
thanks everyone for the help! got me some stock GMPP replacements... anyone have any advice on how to not over-load or under-load finding 0 lash? I do it w/ the motor running and wait for no clacking, then add the prelash. This is my 2nd lifter to go bad, but at least each time it was only 1 lifter at a time... enough to make me never want to buy comp again though =/
Old Oct 11, 2005 | 04:51 PM
Z95m6's Avatar
If they are stock replacement style lifters you'll want to run more than 0 lash.
Old Oct 11, 2005 | 05:07 PM
JustNO's Avatar
Bret
What should be the preload for MOREL after 0 lash ??
My new engine is ready to drop in with new style R lifters, but after I read all of bad stuff I decided to get MOREL and throw the R lifters witout using..
Old Oct 11, 2005 | 05:10 PM
will62085's Avatar
run the r's at zero lash and youll be fine, all the failures are from people with too much preload, the r's are very sensitive to adjustments, and if you lash them like an oem, youll pretty much bottom out the plunger, hence all these failures
Old Oct 11, 2005 | 05:14 PM
JustNO's Avatar
You are right, but new style comp Rs are really junk.. Off course preload shouldn't be like OEMs .. My preload is 1/16, but I think this is not only about preload.. There is something wrong with new style I'm sure.. All the people who have not a problem with R lifters, use the OLD style R not new style..
Old Oct 11, 2005 | 05:37 PM
will62085's Avatar
ive got about 4,000 miles on mine from my old motor, and never had a problem, they are the new style...i plan on using them in my new motor...we'll see what happens
Old Oct 11, 2005 | 05:44 PM
Z95m6's Avatar
Its funny because there are experienced people like Brett saying these things are junk and you should run them, yet there are plenty of people here who think they can. You dodged a bullet for 4k miles, why risk it again.
Old Oct 11, 2005 | 05:48 PM
will62085's Avatar
because the reason they fail is from too much lifter preload, or INCORRECT lashing, if they are lashed correctly, that clip that usually fails WILL NOT see any undue stress...therefore will not break, they are only breaking because people are not lashing them correctly
Old Oct 11, 2005 | 05:58 PM
JustNO's Avatar
Don't type Bret's with 2 "t" He become angry lol
Maybe you got old style one because you used them for 4000 miles and its not a short time I guess..
