Lift or Duration
Old Apr 17, 2004 | 09:12 AM
SantaCruz163's Avatar
Lift or Duration
In a street engine what is more important in the cam being used? Would you want more duration or more lift and why? I think a longer duration would be more reliable because it would put less strain on the valve train components. Anyone have advise?
Old Apr 17, 2004 | 11:14 AM
BPS's Avatar
BPS
I don't think you can just pick one over the other - as your missing a variable.
the 3 factors would be lift, duration and head flow.
High lift would be useless on heads that don't flow well at higher lifts so you would want more duration and lower lifts.
So in large part your heads determine optimal lift.
Another big factor in decision making is cost - high lift cams will require better valve trains.
RUENUF
Mar 13, 2016 03:37 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
dkred94z
Sep 22, 2015 11:24 AM
Daluchman1974
Sep 11, 2015 06:12 AM
