Header gasket and bolts
Old Apr 17, 2004 | 02:41 AM
02transam 513's Avatar
Gonna have to redo my header gaskets soon, and need to know, will the locking bolts from Thunderracing, keep me from having to tighten them? And any thoughts on the best gaskets to use? What about Flow techs aluminum exhaust gaskets, there supposed to seal really well.
Old Apr 17, 2004 | 06:46 AM
jkipp84's Avatar
I've been using the ARP stainless header bolts for a few years now. If I remove and reinstall a header, I do have to tighten them a bit one more time after a heat cycle, then they're good to go. They're pretty cheap and work great.
I've seen some people on here complain about lack of space for the locking bits of the Stage 8's near certain primaries (I don't recall which), but some have no problems. Probably those with MAC's or another 1 5/8" header.
I don't know about the aluminum header gaskets, but I have tried the ones for the collector to y-pipe. Both sides blew out within a month. I've since switched to Mr Gasket ultra seal collector gaskets and have had no problems. For the headers, I'm using Felpro's. Also no problems.
Hope some of this rambling helps
Old Apr 17, 2004 | 10:00 AM
whiteslpz's Avatar
Well I have had my headers on since last june and I have had no problems. I use stage 8 bolts which I have had to only tighten once, and I also use percy's dead soft gaskets
Jason
Old Apr 17, 2004 | 11:43 AM
stereomandan's Avatar
I'd say either Mr. Gasket Ultraseals, or Felpro 1406's for the header gasket. They are similar in design.
For the bolts, I just used the ones that came with my MAC's. I tightened them twice, and they are staying put.
I would recommend the Breslin spitlocks instead of the Stage 8's, if you want a locking bolt.
I prefer the 1" normal header bolts myself. Cheaper, and work good.
Dan
rick350
Mar 16, 2015 02:59 PM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
thenewkid
Nov 27, 2014 09:41 AM
