Lets Play: Whats that Hose Called?
The hose coming off the waterpump and then down and around towards the left side of the engine bay to the radiator is called what hose? "Lower left radiator hose" ? Its not a very big hose, just hoping someone could tell me the exact name cuz i know none of the dufaces at the parts store will know.
Cory
Cory
Re: Lets Play: Whats that Hose Called?
Its called the water pump hose I beleive, but I would ask "shoebox" about this one he has a large parts list. If you goto autozone they will tell you the name, just look at the part number on the hose and give it to them and they will give you the name and everything.
Cory
Cory
http://shbox.com/1/93-94_hoses.jpg
on shoebox' diagram is the 'engine bypass hose'.. GM p/n 10197675
If it's not that hose, tell what # it is and we'll try to ID it..
Charlie
i have confirmed it to be a heater hose problem. That long hose that actually has an "in" and an "out" that goes all the way back up to the dash. Well its leaking antifreeze, so i guess i gotta replace that whole thing which i imagine wont be to cheap.
Cory
Cory
Cory
Cory
http://shbox.com/1/heater_hoses_93-94.jpg
and I'll give you the GM part # and a way to change just that hose...
You do not have to change the whole heater pipe and hose assembly..
That hose is the one that would feed coolant to the oil cooler, if equipped. Otherwise, AFAIK, it is no big deal. Just buy a piece of heater hose as there are no bends in it. IMO, it would be a waste of money to buy the GM hose for way more money than 3 feet or so of heater hose the appropriate size.
Ryan
Ryan
anybody have an idea what sieze heater hose this would be? 1/2 inch? 3/4? 5/8? Im fairly positive that the only spot it is leaking at is right at the spot where it connects to my water pump. The heater hose is just worn out i guess. So i need to go buy like Ryan94 said...3 feet of hose ( trying to find out what size ) and clamp it in place of the old worn out hose up to the metal part of the hose im guessing.
Cory
Cory
Well tell me what HOSE # in this diagram it is and I can tell you what SIZE the hose is..
there are like 6 heater hoses on these cars..
I posted this did you see it?:
Which hose on here on shoebox diagram?
Tell me which hose # in the diagram is leaking..
I'm thinking from the diagram...this hose would be #12 ??? hooks right onto the waterpump...then comes down and attaches to the metal hose and runs back into the dash. Thanks
Cory
Cory
That's 3/4" ID
Try to maybe find a preformed elbow[3/4" ID] in Pep Boys etc..
Don't forget that the 'flow restrictor' is in there[look for it.. it's not far down that hose from the water pump.. #13 on the diagram..]
The hose from the water pump does not go all the way to the hard pipe.. the flow restrictor is in there..
You can cut the swaged aluminum clamp off the flow restrictor and replace it with a worm type clamp..
[Problem] F-Bodyworld.com/Jon Massaro WARNING!!
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
