lets hear your LT1 custom cams
Old Dec 2, 2007 | 11:02 PM
  #31
black97lt1's Avatar
good stuff guys
Old Dec 3, 2007 | 03:00 PM
  #32
Compstall's Avatar
Originally Posted by Steve0
Whats your idle set up? Your hotcam has a lot more lope than mine.
If you leave the stock idle alone, the Hotcam lopes heavier. Most tuners will raise it a hair so it'll run smoother.
Old Dec 4, 2007 | 08:29 AM
  #33
Z-RATED94's Avatar
Exactly, 100-150 more rpm can make a big difference at idle.
Old Dec 4, 2007 | 02:20 PM
  #34
rickreeves1's Avatar
Originally Posted by HardcoreRM125
BRE Cam. Slightly larger than a LE1.5. PCMforless Tune. Runs strong, no numbers till spring. Tracks are closed and the car is getting put away before the ****ty winter weather so no dyno #'s yet. It pulls hard to 6200-6300ish though. Decent driveablity. Only is annoying in traffic or chugging at idle through a parking lot. With an A4 the surge would be totally gone I think. Or possibly a little more work on the <5% throttle in the tune.
Cold Idle : http://videos.camaroz28.com/recentvi...470b1004-c859-
4170-ac7a-999b001728a1.htm
The idle video link dose not seem to be working. I have a similar setup and I'm thinking of getting the LE1.5 cam. I'd like to hear more of this cam with open pipes if anyone has more videos. Thanks
Old Dec 4, 2007 | 06:44 PM
  #35
HardcoreRM125's Avatar
Link Fixed, sorry about that.
Mines coming through Pacesetter long tubes, ORY, and a 3" Cut out dumped before the rear axle. Muffler is a Flowmaster, and you still get some of the tone of it even with the cut out open. Since i put it on, I have not closed it yet. Just coast past the police and your fine lol.
Old Dec 4, 2007 | 09:04 PM
  #36
95Bird's Avatar
Here is my old setup that went 10.39. 255/263 solid going through true duals with bullets. Idle around 1000
http://formula95.ls2.com/Video/idle.wmv
here is same setup making a pass..you can hear the idle at the start of the video. I tried launching at 6800 not on the 2 step and it didn't go so well.
http://formula95.ls2.com/Video/6800launch.wmv
here is the new setup. Custom grind Futral Motorsports solid roller. 26x/27x on a 110...lift around 700ish..hehe. Still a 355 and still going through dual bullet mufflers. Its in my shop so you get alittle echo and sorry about the smoke..I didn't have my MAP hooked up so it was pig rich. Idle around 1200
http://formula95.ls2.com/Video/newsetup.wmv
Old Dec 4, 2007 | 09:46 PM
  #37
marshall93z's Avatar
Damn!
Old Dec 5, 2007 | 11:35 AM
  #38
Thumbs up
I like it!
Old Dec 5, 2007 | 11:41 AM
  #39
maybe2fast's Avatar
CC503, 918s, PP, Pacesetter LTs, Magnaflow Catback, no cats, and some extra stuff
Old Dec 6, 2007 | 11:34 AM
  #40
Type_O_Negative_1320's Avatar
Comp Cams custom grind...236/236 @ 0.050", 0.608"/0.608" lift with 1.6 rockers, 113(?) LSA (it's been a while since it went in).
Breaking it in, redneck style.
On the dyno (after swapping the motor into a new body, old body was beat).
415RWHP/383RWTQ (385ci LT1, through a T56 and Moser 9")
Old Dec 6, 2007 | 04:01 PM
  #41
'94 Bad A Z28's Avatar
Not a custom cam but here is my 847 through a closed cut out to a flow master...
Old Dec 6, 2007 | 10:16 PM
  #42
rock1501's Avatar
heres mine the rpm is at like 1500-1700 cause I dont have the tune just right yet
http://www.youtube.com/watch?v=tJ6eOv_9haQ
Old Dec 7, 2007 | 12:55 AM
  #43
AZ2ENVY's Avatar
Sorry for the crappy quality Ill have a better one soon . This
video doesnt even begin to catch how much this cam lopes
Oh well it will do for now
Comp Cams custom grind 233/239 XE .569 .577 111 lsa.
Old Dec 7, 2007 | 02:58 AM
  #44
KWIK WS6's Avatar
From: Southern California, where do YOU live mutha****a?
Not custom but 847, first is start up secons is later that night
http://www.megaupload.com/?d=H4VUJ8PC
http://video.google.com/videoplay?do...86132892612506
Old Dec 7, 2007 | 01:03 PM
  #45
What's your exhaust setup? That thing sounds BADASS!!
