Let the fun begin
Let the fun begin
Ok, finally I am ready to get underway on modifying my car. Currently I have a 1994 Z28 T56 with 32,955 miles. The ONLY thing done to the car is the SLP LM exhaust system. I am ready for something else. I want to go ahead an put a cam in it. I have to replace the plugs, wires, and valve cover gaskets, so while I am under the hood I want to do it all at once. Now is where I need your help. If I put a cam in my car, do I need to do ANYTHING else to it, such as an aftermarket intake, new vavle springs, etc., and if so what brand should I go with? Also, with the actual cam, what grind and brand should I go with on that? I was reading on T-Byrne motorsports that a 210/272 grind should be fine. Is that correct? I don't plan on doing any MAJOR modifications such as going into the block anytime soon, I just want to run in the mid to high 8's. What brand plugs and wires should I go with? Like I said, I only have the SLP LM exhaust system, do you recommend me investing in the LT4 knock module or a 160 degree thermostat or any other accessories. I am putting my F-Body in the mercy of your hands, if it were as your own. Just trying to gather some opinions, thanks for your help.
Steve
Steve
Yea, I would do headers and a y-pipe. While you are doing that do a high flow cat too so it opens it all up for the cam. I would do a LT4 KM at the same time also. ANd you know what they say the Cold Air Intake is one of the best buys you can make for the money. But it isn't needed to do the cam. I would start thinking of that after the cam.
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
cmsmith
Sep 14, 2015 09:25 PM
Sep 11, 2015 09:44 AM
Aug 3, 2015 08:42 AM
